Location of sub-woofer installment
Vibe-agra
Post by Vibe-agra »
Some owners have added a sub-woofer to their stereo to upgrade the base. Where would be a good location to install it?
Mikey2003 Pontiac Vibe Base, 4-speed auto, Abyss, monotone, Moon and Tunes, Power package, in-dash 6-disc CD, ABS, Side curtain Air-bags, Security System, Cargo box,Cargo mat, s/s exhaust tip. Ching Ching1996 Honda ST1100ABS
Sub-Vibe-R
Re: Location of sub-woofer installment (The Vibrator)
Post by Sub-Vibe-R »
I put mine in the trunk. Wiring pass under the platic at the bottom of the doors, then under the rear seat and come out in the trunk from the existing hole for child seat. I drilled only 1 hole, in the platic between the rear seat and the trunk.
ourvibe
Re: Location of sub-woofer installment (Sub-Vibe-R)
Post by ourvibe »
I installed a JL audio microsub in rear hatch area. Sub was mounted using JL supplied mounting bracket to the vibe track system. I can still open cover over spare without removing sub. Wiring was run under carpet from amp under passenger seat. No holes drilled. Sounds great and takes up little room.
2003 Vibe AWD AutoMonotone Satellite
Sub-Vibe-R
Re: Location of sub-woofer installment (ourvibe)
Take a look to my topic. You'll see all my installationhttp://forums.genvibe.com/zerothread?id=2524
NY Pete
Post by NY Pete »
You gonna clean that up bit when it gets warmer? all those exposed wires going to the amp, amp mounted to the box... messy messy IMHO...
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
Sub-Vibe-R
Re: Location of sub-woofer installment (NY Pete)
quote:You gonna clean that up bit when it gets warmer? all those exposed wires going to the amp, amp mounted to the box... messy messy IMHO...Messy but easy to remove when more space is needed. 3 screw, 2 RCA and pop, no more sub.
NY Pete
Post by NY Pete »
Oh you made it so you can remove it. MY bad.
