Increasing the MPG
burrpenick
Increasing the MPG
Post by burrpenick »
Is there any inexpensive and simple tricks to increase the MpG on my base engine VIBE? penick@nettally.com
goodvibe
Re: Increasing the MPG (burrpenick)
Post by goodvibe »
Drive slower(acceleration and top speed) and use the highest appropriate gear. Use the min. acceptable octane (87). You'll get better combustion and power than a higher octane. I know these seems too obvious but there isn't much else you can do but perhaps use a thinner oil like Mobil 1. There's a wide range between 20 and 40 wt oil. Some 30wts are thinner than others and M1 is one of them. If you have a manual, you can also pick a gear oil that's on the thin side of spec like Torco.
drunkenmaxx
Re: Increasing the MPG (goodvibe)
Post by drunkenmaxx »
actually, if you behave yourself, the CAI will help also!
goodvibe
Post by goodvibe »
It would depend on the intake, MAF position and how much leaner it's actually running from the intake. Hardly foolproof but the right combo could do something as you are running a leaner mix. Part of how a cai makes power is gettimg the A/F right at full throttle by leaning out the mix (stock is rich here) but often leaves things a bit lean for normal driving. Hence better mileage but less power at lower throttle positions and low rpms. Not what I would want if I was trying to take it easy.
Mr. Poopypants
Post by Mr. Poopypants »
GMJAP
Post by GMJAP »
Never let your RPMs go above 3000. Unless you're in top gear, never cruise at more than about 2250 RPM. If you start exceeding that, upshift. (On the bottom side, never let the RPMs get below 1800 - downshift)
