sulphur smell for an '05
21Rouge
Post by 21Rouge »
I have put about 500 km on this brand new manual 05 Vibe. I do notice the suphur smell upon getting out of the vehicle. That is, I dont notice while in the car and driving. Should I put on more mileage and see if it continues? I know this was a problem with 03 and 04 auto Vibes and a TSB was issued. Anyone else noticed the smell for this year's Vibe?
ragingfish
Re: sulphur smell for an '05 (Boxgrover)
Post by ragingfish »
Is it sulfur, or burning plastic?I've run over plastic bags in the road twice. Both times, they got stuck the cat and started melting. I could only smell it outside the car.Be sure before you rant to the dealer about sulfur...
2009 PONTIAC G8
21Rouge
Re: sulphur smell for an '05 (ragingfish)
Post by 21Rouge »
Quote, originally posted by ragingfish »Is it sulfur, or burning plastic?Be sure before you rant to the dealer about sulfur...Definitely sulphur but with 500 km on the car I wont go to the dealer about it unless it is still there at 3000 km.
GMJAP
Post by GMJAP »
Quote, originally posted by Boxgrover »Definitely sulphur but with 500 km on the car I wont go to the dealer about it unless it is still there at 3000 km.I get the sulphur smell too. It's intermittent, and I only smell it sometimes when I park in the garage, upon getting out. Never smell it in the car either. I'm at about 10,000 miles, and it seems to happen less often than it used to.
ragingfish
Did you use a brand of fuel that you don't normally use on this last fill? Did you go to a station you don't normally use? Try either changing brands altogether, or going back to a station you normally use. If it goes away after a tank or so, your fuel was the issue.Top Tier gasolines are ideal:QuikTrip, Chevron, Conoco, Phillips, 76, Shell, Entec Stations, MFA Oil Companyhttp://www.toptiergas.comNot sure if top tier applies to Canadian fuels, but I recently switched to Shell and, despite the 2-3 cent premium price, have noticed dramatic improvements in fuel economy. No-name branded fuels may also have a tendency to produce, um..."odors."
2009 PONTIAC G8
21Rouge
Re: sulphur smell for an '05 (GMJAP)
Post by 21Rouge »
Quote, originally posted by GMJAP »I get the sulphur smell too. It's intermittent, and I only smell it sometimes when I park in the garage, upon getting out. Never smell it in the car either. Actually that describes my situation EXACTLY. GMJAP is your Vibe an '05? And I guess you think that the sulphur odour associated with your engine is not indicative of anything more serious.
iinan
Post by iinan »
the only time that I get the sulphur smell is after I have had chili for lunch.
2004 GTMagnaflow/Cosmo CAI/TRD Strut brace/Hotchkis springs20-15 tint/Unichip/18 Konig "trouble" wheelshttp://members.cardomain.com/iinan
21Rouge
Post by 21Rouge »
Quote, originally posted by ragingfish »Did you use a brand of fuel that you don't normally use on this last fill? Interesting url ragingfish. Thanks.As you may know my week old Vibe has just over 500 km on it. First tank was from Shell, the second from Esso. Again I notice the odour when I park it in the garage...I guess the exhaust vapours are trapped in concentration within the garage.
ragingfish
Try shell again next time, see if it goes away.
2009 PONTIAC G8
tnpartsguy
Post by tnpartsguy »
The '05's have been included in the TSB.http://forums.genvibe.com/zero...age=5
BlueCrush
Post by BlueCrush »
Are you smelling it every time? I had that same smell a couple times in the first 1000 miles. I haven't smelled ti since and I am at 10000 currently. I would say wait until you get over 1000 miles and if it is still there then get is replaced under the TSB which, as tnpartsguy mentioned already, now includes the '05's.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
BlueCrush
Post by BlueCrush »
Double Post! My Bad.
My Fleet:
Re: (tnpartsguy)
Quote, originally posted by tnpartsguy »The '05's have been included in the TSB.Oh wow - I'm puzzled at why this would still be an issue! Logic would dictate that the '05 models would come with the correct PCM and the new cat. But that makes too much sense, so they just decided to replace half of the problematic components.
Image Image
21Rouge
Re: sulphur smell for an '05 (BlueCrush)
Post by 21Rouge »
Quote, originally posted by BlueCrush »Are you smelling it every time? I had that same smell a couple times in the first 1000 miles. I haven't smelled ti since and I am at 10000 currently. I would say wait until you get over 1000 miles and if it is still there then get is replaced under the TSB which, as tnpartsguy mentioned already, now includes the '05's.I will wait. But it appears that the TSB doesnt include a manual transmission.
