Another AUX2Car install sucess
04kvibe
Post by 04kvibe »
Just got the adapter installed...works great, easy install (thanks to my hubby) for those who don't want to replace the HU. Just for clarification I have an 04 with the single disc & M&T.Thanks to all who posted info and how to's on this product. Couldn't (wouldn't) have done it without you. Here's the link for the adapter.. http://www.discountcarstereo.c...D=749Product ID: PXDX Product Name: Peripherals AUX2Car Auxiliary Input Adapter with Free Cable. Price: $75.98 Select Cable - PXHGM3 Vehicle Year/Make/Model - Vehicle Year/Make/Model 04 Pontiac Vibe Best price you'll probably find, $84.46 with the shipping... ordered on Tuesday evening...arrived in the mail Friday.Now, if my new Rio Carbon worked...but that's another story
2004 Base Vibe: Abyss Monotone, M&T, Power Pkg.BF Goodrich Traction T/A's on 16" American Racing Wheels: EstrellaLund Hood Deflector, 3M Clear Bra, Hidden Hitch, "Lowes" Cargo Mat...
remusrm
Post by remusrm »
i will order this too... today... kind of worried, since i got the 6 cd in dash...
09 MazdaSpeed3 ZOOM-ZOOM
04kvibe
Re: (remusrm)
Post by 04kvibe »
I think the jury is still out on whether this will work with the in dash changer.Just to be sure, I would wait till Monday to call and ask unless you can get a definitive answer from someone here. just my opinion
benwellington
Re: (04kvibe)
Post by benwellington »
I want to know too! I called and they said it would work fine with the indash changer on the 2005 vibe. You just hook it up to the 12 pin in the back.But I am waiting for confirmation before I buy it too.
2005 Platinum base, M&T (6CD), Leather, Alarm, Monotone, PowerGroup, ABS, 17'' wheels, Curtain airbags.
Jahntassa
Post by Jahntassa »
Do you have XM, Onstar on your '05? It's possible that you might have to disconnect and/or lose functionality of one or both.Just a warning..this is uncharted territory, so please let us know how it works out with the 6-disc!
GMJAP
Re: (remusrm)
Post by GMJAP »
Quote, originally posted by remusrm »i will order this too... today... kind of worried, since i got the 6 cd in dash...I hate to ruin the party, but it won't work on the 6CD.(Unless you somehow got one with a BAND button. And if so, I really want to talk to you!)That's a definitive answer. I've tried it.
dan326
Re: Another AUX2Car install sucess (04kvibe)
Post by dan326 »
Where is the power wire hooked up on your aux2car adapter?
04kvibe
Re: Another AUX2Car install sucess (dan326)
Post by 04kvibe »
to the blue wire w/ white stripe in the radio harness...I'm glad we got the in dash 6 CD problem answered...sorry guys
dan326
Post by dan326 »
Did your adapter harness have just one yellow power wire or was there a ground wire coming out of the harness as well?
GMJAP
Post by GMJAP »
Mine had just the yellow power wire. It grounds through the radio 12-pin
remusrm
Post by remusrm »
so this will not do anything for me since i got the 6 cd in dash, no band button and also no xm/nav...
dan326
Re: Another AUX2Car install sucess (GMJAP)
Post by dan326 »
Where did you connect your power wire? No ground loop and alternator whine for you?
GMJAP
Re: (remusrm)
Post by GMJAP »
Quote, originally posted by remusrm »so this will not do anything for me since i got the 6 cd in dash, no band button and also no xm/nav...Unfortunately, correct.Quote, originally posted by dan326 »Where did you connect your power wire? No ground loop and alternator whine for you?Answered this in your thread. Briefly: to 24-pin Blu/Yel
kcinmi
Post by kcinmi »
Sounds like she tapped into the blue wire with a white strip, constant 12 volts to the radio. Thats the same place I tapped into, no whine or noise of any sort. I do wonder, if anyone may be able to answer, instead of tapping into constant 12 volts, why not tap into switched 12 volts? I wonder if it would do away with the white noise I get after I shut everything off?
God, grant me the serenity to accept the things I can not change,the courage to change the things I can, and the wisdom to know the difference.
Jahntassa
Post by Jahntassa »
Depends on what the adapter needs. If there're any settings it has to store or anything, having the constant power switch on and off might cause problems down the line. I doubt it would have anything to do with the 'white noise'.. Especially if the radio is off. But..who knows for sure..
04kvibe
Re: Another AUX2Car install sucess (kcinmi)
Post by 04kvibe »
Yup, that's where it is, haven't heard any noises...The little I have used it anyway. I bought to use with an mp3 player, got a 5 gig Rio Carbon...it had issues had to take it back.I have a Zen Micro on order from Circuit City, should be here by the end of the week, can't wait
