ok.......my Vibe hasnt hit 2400 kms yet and now when I get to 3000 rpms something is rattling under the hood...happens in any gear...(I have the manual tranny)...any suggestions as to what could be causing this???
check your platic engine cover, maybe its loose. I know I had a rattle under the hood after I put my cold air intake in... I had removed the engine cover and it was a little loose afterwards.
Sunny, check out the search for that dash buzz... Im pretty sure there is a step by step on how to fix that one. I have the same problem, I just tend to ignore it or turn up the radio.
I did a search but I guess I didn't use the EXACT words necessary to find the step by step.Quote, originally posted by Ponyota »Sunny, check out the search for that dash buzz... Im pretty sure there is a step by step on how to fix that one. I have the same problem, I just tend to ignore it or turn up the radio.
Quote, originally posted by Sunny »I did a search but I guess I didn't use the EXACT words necessary to find the step by step.Perhaps the thread is this one, which contains a link to disassembling the dash:http://forums.genvibe.com/zerothread?id=7631
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse.(Romans 1:19-20) What do you want most in life?
Hi gpk,Does it happen when in neutral as well? Could be just about anything loose or rattling near the engine. I say near the engine simply because the RPMs cause the issue. I would look for something that may have come loose or something that may be metal that could be rubbing/bouncing up against something else in or around the engine.Should be an easy thing for a dealership to find since it seems to happen regularly. Rattles shouldn't happen and unless you altered something that's causing the issue, any diagnosis/repair should be covered... I'd hope.Last Summer I was doing a bit of work under the hood. Added Ground Wires, changed Manual Transmission fluid and a few other things. Shortly after doing some of the under the hood work, I noticed at idle there would be a grinding noise, heard when the radiator fan was on, usually when at a slight incline. It didn't happen often but occasionally. I let it go until a trip to SC. Became more annoying. I had checked before but didn't notice anything but this time I decided to give a more close look. Found my sunglasses stuck near the fan blade. It would sometimes rub the blade, sometimes not. I honestly thought it was the ground wires I had installed but nope, I forgot to get my glasses once before closing the hood. Dave
I have a rattle at low rpm, coming from my windsheild defrost... it's only when my fan is on low setting, I'll get it looked at before my warranty is up in 45000 kms... For now I just turn up the stereo!
2004 Neptune Two-Tone Vibe w/Sports Package (sunroof, aluminum wheels, upgraded 6-spkr stereo), Tinted windows (35 front, 5 back), Cool Blue Headlights/Foglights, genvibe decals on the roof rack, Mr. Grille Aluminum Billet Grilles, GM Exhaust Tip sensfanrk
yes it happens when in neutral as well...sorry...thats something I didnt mention....still does it....havent had time to even call the dealer about this...i'm sure it's minor.....ya know..just something of breaking the car in kinda thing...but it sure is annoying.Going to call the dealer this weekend about it.your sunglasses Dave?....lol...thats too funny....I have 2 pair and yup....still got mine both accounted for....lol
Yes i have this exact porblem the dealer says they don't hear it or say they have fixed it but never tell me what they supoosdely do. i can't take the absoulte idiots at my dealer anymore. but it is still under warrenty and still there problem, but if someone could figure this out and give something to tell them to fix that would be great. i don't want to take apart my whole dash, for one i think i would only end up with more rattles after that, and for another because it could void the warranty. it sounds like it is coming from between the radio and the defrost vents to the windesheild any help would be great this noise is killing me
