Probably remove and replace, or maybe more accurately remove and reinstall, it's sort of the CTRL-ALT-DEL method of repair, take it apart and put it back together, see if that fixed the problem. I guess if you take it apart and can't see anything to fix, the only thing to do is just put it back together.col., So, the dash moves forward and backward? I can push on the top left front of mine by the light sensor and it gives some, vertically, like it is not anchored up by the windshield, but the edge away from the windshield is pretty solid.I had a dash brace by the glove box fall out of my dash (see the bottom part of
http://forums.genvibe.com/zerothread?id=5933 ) I have never had the dash apart enough to know if there is anything similar on the drivers side of the dash, but maybe one fell out of your dash or was never installed, and the dealer didn't notice it was missing. Can be hard sometimes to identify a missing piece if you don't know its supposed to be there.
