bug deflector
Waxler6942
bug deflector
Post by Waxler6942 »
Where can you find a perfect fit bug deflector/hood protector that installs with clips instead of screws or tape?
2003 MonoTone Base / MT PackagePioneer AVIC-N1 with Sirius TunerPolk db6500 ( front ) Polk MMC650 ( rear )Directed 750d Amp ( underback seat ) pushing Polk Momo 12" Focal F10 18Rain Guards 2% Tint in Rear with Drips on FrontPainted Side MirrorsCustom Hood
redlava
Re: bug deflector (Waxler6942)
Post by redlava »
litefoot
Post by litefoot »
I have a Lund Xterminator bug shield on mine.It uses four pieces of heavy plastic tape to protect the paint. Then fourC clamp type clamp that uses a flat end screw, to put pressure on the under side of the hood to hold it on. There are no drilling holes for the screws. I am guessing that what you mean by screws. I have removed it to clean the hood, if you remove the tape you cannot tell it was on.
2004 Vibe AWD Neptune BlueMoon and TunesPower/Security Package1998 Chevy Tahoe"WHAT I HEAR, I FORGET. WHAT I SEE, I REMEMBER. AND WHAT I DO, I UNDERSTAND."
Waxler6942
thanks that is exactly what i was looking for i am going to order one soon
21Rouge
Re: bug deflector (litefoot)
Post by 21Rouge »
Quote, originally posted by litefoot »It uses four pieces of heavy plastic tape to protect the paint. I have removed it to clean the hood, if you remove the tape you cannot tell it was on. Is the "plastic tape" you are describing (for use on paint) readily available as a separate, simple inexpensive item?
litefoot
Re: bug deflector (Boxgrover)
Post by litefoot »
I not sure, I know it is a 3M product.The speed shop I deal with is closed on Mondays.I'll call them Tuesday to see if it is a common part.I emailed Lund tech support. When I get an answer, I'lllet you know. I think I was lucky, I had two sets of tape in the box when I got it.
21Rouge
Post by 21Rouge »
Quote, originally posted by litefoot »I have a Lund Xterminator bug shield on mine.I went to Lund's website. It shows two similar products Carflector™; Stone/Bug Deflector for a 2005 Vibe Part no: 20037 http://ventshade.r-catalog.com...=5727!also there is the Xterminator bug shield Part no: 78554 http://ventshade.r-catalog.com/ymm.aspCan someone explain to me the difference between these two shields?
litefoot
Post by litefoot »
Here is some pictures of my Lund Xterminator bug shield.Hope it give you a better idea about the install
AKLGT
Post by AKLGT »
lund carflector:
AKLGT1998 Subaru 2.5RS
kostby
Post by kostby »
And the difference between them is .... ?
litefoot
Re: (kostby)
Post by litefoot »
I tried to blowup trbvibe’s pictures to get a better look at the bug shield. It looks like the Xterminator is more body contoured where the Carflector is less contoured. And the Xterminator’s mounting clips go through the top to the bottom. And Carflector’s looks like it mounts from the bottom. I can’t tell if they both use the same kind of fastener. The Xterminator has a straight bottom edge where the Carflector looks like it has a rounder bottom edge. Please correct anything that I am wrong about, trbvibe. Unless the way they are fastened to the hood is different. It comes down to, do you want contoured or the less contoured look.
AKLGT
Post by AKLGT »
if you want to use either for what they are actually made for, don't think it's going to help a whole lot. i took mine off after 2 summers worth of chips, window dings, and cracks. imo, it sucked and looked like crap on my vibe. but that's just my opinion.
