'03 torsion beam question
Thewhite
Post by Thewhite »
ok, I'm French, and not in mechanics, so I'm not sure if I will be clear, but lets try it. Is it possible to change the '03 rear torsion beam to an independant rear suspension, like the '05?
'03 Vibe StandardFast Wheel Talon 17x7 Toyo Proxes T1-S 225/45Magnaflow Cat backDevelop's Strut Tower Brace
ragingfish
Re: '03 torsion beam question (Thewhite)
Post by ragingfish »
Only the AWD models get independent rear suspension. 05 base and GT models still have the torsion beam.That being said, you probably could convert it, but the amount of money that would be needed to make it all work would probably negate any benefits.
2009 PONTIAC G8
Thewhite
Re: '03 torsion beam question (ragingfish)
Post by Thewhite »
ah, I probably saw a AWD then... is anybody know why Pontiac and Toyota didn't go with an independant at rear suspension, to follow Mazda and others??
I read somewhere in a Corolla review that they chose to go with the torsion beam setup was due to ride quality... They placed empasis of ride quality over handling in that car, so thus here we are... At least that sounds like a good theory.
