Hi again...As I said, If you get stuck with the bulbs, you could always purchase new sockets that are made to handle the increased wattage. They generally come with long enough leads to get you far enough away from the source heat. Also, not all members have had bad results from the higher wattage bulbs... see
http://forums.genvibe.com/zerothread?id=687 But again, as I said before, it's not worth the risk. Either sell your bulbs or get the higher wattage capable sockets. If you decide to keep em, give us some before and after pics.Dave
