Brand of coolant to use for a top off??
Kissfan79
Post by Kissfan79 »
Anyone have any suggestions for a brand of coolant to top off my coolant overflow with? I have read some past topics on coolant and looked in the owners manual about the coolant type and I get the impression that I should be picky about the type of coolant to use. Any auggestions for an 03 GT?Thanks, Jim
Abyss Vibe GT monotoneMoon & Tunes w/6 disc changerCargo nets and mat93 Octane w/ lots o' KISS in the CD changer
Raven
Re: Brand of coolant to use for a top off?? (Kissfan79)
Post by Raven »
Get the stuff from the Toyota dealer. It might be slightly more$ but you can't go wrong.
ToolGuy
Post by ToolGuy »
I have not flushed mine yet, will do in the summer but I have heard the Toyota coolant is just normal green just tinted red. It is not extended life red like others. Makes sense too since it is recommended to be changed every couple of years or what ever the manual states. As far as I know there are only the two types as far as life range out there, the entended life and the old normal green.Search the site on coolant change and I am sure it was discussed at length. Some have taken their cars into Toyota and discovered the above.
tnpartsguy
Re: Brand of coolant to use for a top off?? (MiVibe-ToolGuy)
Post by tnpartsguy »
The Toyota isn't just tinted red. Unlike the traditional green, it has no silicon or silicates, thus no build-up on your water pump, ect....
ToolGuy
Re: Brand of coolant to use for a top off?? (tnpartsguy)
Post by ToolGuy »
So there is a difference? Three kinds of coolant now, Toyota Red, ext life Red and Green?
redlava
Post by redlava »
I would think that just as long as it is the Dexcool stuff you shouldn't have a problem. I have a bottle of the 50/50 Prestone.
champcaracing
Post by champcaracing »
toyota has 2 different coolants, long life red and super long life, which is also red. toyota has always had red coolant for as long as i have been working at dealers. volvo uses blue colored coolant.
03 toyota matrix XRS 6 speed, lunar mist,factory 17 inch rims w/firehawks- summer tiresfactory 16 inch rims with dunlops- winter tirestrd sway bars, trd strut brace, trd sport muffler,trd quick shifter,trd cold air intake, toyota tundra dual horns,factory toyota wing from toyota canada, both front door handle modsNEW pioneer AVIC-D1 nav unit, XM radio installed
ToolGuy
Re: (champcaracing)
Post by ToolGuy »
So then what is the life of the Vibes coolant???? The owners manual states changing at 30,000 or every 24 months using an Ethylene Glycol Base coolant. Does not sound like long life to me...
Kissfan79
Re: (MiVibe-ToolGuy)
Post by Kissfan79 »
So...after the disucssion so far....what brand should be used if I were going to some place like Wal-Mart or an Advance auto parts to buy a gallon to top off? One could never dream that looking for the correct coolant would be so research involoved Jim
tnpartsguy
Quote, originally posted by MiVibe-ToolGuy »So there is a difference? Three kinds of coolant now, Toyota Red, ext life Red and Green? Yeah, and as mentioned Toyota has 2, Volvo has blue, and Medium Duty GM Trucks use a totally different coolant. I use the normal Toyota Red in everything, Part # 00272-1LLAC.
