DRL Gripe
esjones
DRL Gripe
Post by esjones »
I really don't mind the DRLs, since I don't see them when I'm driving! There is one aspect of their operation, though, that really bugs me.On a recent chilly evening, my wife and I were out running errands. I stopped at a store to run in, and she stayed in the Vibe. I wanted to leave the car running to provide heat, but I wanted to turn the headlights off. I had to set the parking brake, turn off the engine, then when I restarted it, the DRL system did not come on because the parking brake was set. (I have a base 5-speed... I don't know if the automatics work the same way).I would really like to be able to turn off the DRLs without having to stop and restart the engine. I think this is a Toyota thing, not GM. Am I right? Any thoughts or suggestions?
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
Mase
Re: DRL Gripe (esjones)
Post by Mase »
I cut the wire indicated in the drl mod how-to and wired a switch in between the wires. This allows me to control drl's and the auto headlights.
tnpartsguy
Post by tnpartsguy »
GM has a switch on the Impala/Monte Carlo police version marked "Survalance Mode" I just ordered one to see if I can make it fit one of the holes, or will I have to cut a hole.
russ257
Re: (tnpartsguy)
Post by russ257 »
do you have a pic of that switch if it looks sweet i might have to do this mod
'03 VIBE AWDPioneer AVIC-N1MOMO 6.5" componets in frontMOMO 6.5" speakers in rearJL e6450 six channel ampJL 12" w3 subAlpine 120W amp powering the sub
tnpartsguy
Here it is. To show the size, that's a dime beside it. It has 3 fingers, because it goes into the alternate trunk release hole.
ragingfish
Post by ragingfish »
There is allegedly a reworked DRL module available from GM that acts like normal GM vehicles: the lights turn off it the brake is engaged, without having to restart the engine.Nick could provide more info on this than I can...
2009 PONTIAC G8
Mase
Re: DRL Gripe (ragingfish)
Post by Mase »
Quote, originally posted by ragingfish »There is allegedly a reworked DRL module available from GM that acts like normal GM vehicles: the lights turn off it the brake is engaged, without having to restart the engine.Nick could provide more info on this than I can...you can do that by wiring a relay between the drl wire and grounding it to the wire that runs to the parking brake switch. It's just like using the parking brake as the drl switch.
