Help Please! Speaker wiring color scheme
joserobl
Post by joserobl »
I have the base stereo in my Vibe and decided to replace the stock speakers with some Polk db650's. I've run into a snag though. I started with the rear doors and found that both right and left door speaker wires are red and white not sure which is - or +. Would anyone Know the wiring color scheme for the base Vibe. I tryed the search but all they give me is for the MT system. Your help will be greatly appreciated.
damronjr
Re: Help Please! Speaker wiring color scheme (joserobl)
Post by damronjr »
Red is always +. It applies here as well.
joserobl
Post by joserobl »
Thanks, would you happen to know the color scheme for the front also? Don't know the colors yet cause I haven't taken the panels off.
damronjr
Re: (joserobl)
Post by damronjr »
joserobl
Post by joserobl »
Isn't that for the MT system? I have the base system. Thanks though for the help
damronjr
Re: (joserobl)
Post by damronjr »
Oops, yeah it is. Should be the same colors. If not, just let us know and I'm sure someone has the chart for that.
joserobl
Post by joserobl »
Just to let you know I finished installing the speakers and it wasn't to bad. I ended up tearing apart the stock speakers to use the same brackets. I come to find though that the stock head unit just isn't enough to do the speakers justis. So now I'm looking at installing an amplifier to the stock head unit. Just want to Thank You again for your help on the wiring scheme. You were right it was basically the same except both the rear left and right are red and white.
