switch for neons,
joholste
switch for neons,
Post by joholste »
i wanted to place my switch for my neons next to the illumination controller for the interior lights and instrument panel, however i can't figure out how to get in behind it, the only way i can think of is to remove the vent cover on the driver side vent by the door, but i can't seem to get it off, does anyone know how to do this? if not i need some other good ideas for placement of the switch. This is what the switch looks like:http://www.cardomain.com/memberpage/733209/3thanks for any help
rcasciola
Re: switch for neons, (joholste)
Post by rcasciola »
the way i pushed my pieces out was i opened that little compartment right there on the drivers side and then i put my hand up there and pushed those pieces out..the blank ones that is. its kinda tough but ull get it.
My Car, with the kit on. it looks awesome! come and check it out, tell me what u think.P.S. the gray will be painted momentarily http://www.cardomain.com/ride/514882/1
satur9
Re: switch for neons, (rcasciola)
Post by satur9 »
me too. however the vent does just pull off if you gently pry up the corners a little.
ragingfish
Post by ragingfish »
Grab the little quarter holder with your finger, yank it out, then stick your fingers in to push the others out from behind.
2009 PONTIAC G8
scherry2
Re: (ragingfish)
Post by scherry2 »
Quote, originally posted by ragingfish »Grab the little quarter holder with your finger, yank it out, then stick your fingers in to push the others out from behind.thats how I did it. they pop right out.
rcasciola
Re: (scherry2)
Post by rcasciola »
yea i eventually found that way out too..lol...
