Help! 2002 Pontiac Grand Prix
halusbr
Post by halusbr »
Help, my 2002 Pontiac Grand Prix headlight burned out. Is there any way to replace it, without going to a mechanic or Dealership Service Center. I can't seem to figure out how to get to the actual lightbuld (opening the casing), and am not sure what kind replaces it. All advise would be much appreciated. Thank you, Brian
ragingfish
Re: Help! 2002 Pontiac Grand Prix (halusbr)
Post by ragingfish »
Try a grand prix forum.
2009 PONTIAC G8
Kari
Post by Kari »
I googled "Grand Prix forum" and came up with several results...including this GenVibe concept-ish site (minus the pretty design) focused on the GP... http://www.clubgp.com Enjoy
GenVibe Global Moderator
Hi Brian, welcome to genvibeThe Vibe owner's manual shows how to change a headlight bulb in a Vibe, but I don't know if it's similar to a GP or not, but check the GP's owner's manual to see if it's in there. It used to be that you could download PDF copies of owners manuals from http://mygmlink.com, but now it appears that you have to register (for free) and then can only download manuals for cars you register on that site. You used to be able to download any of them, but not anymore. If you don't have the owners manual for your GP, you could register there and maybe download a softcopy of it. If not that, then try a GP forum, or maybe someboy here might also have a GP and can answer better.
Looking at Sylvania's automotive lighting search, the GP takes 9007 bulbs. http://www.sylvania.com/Consum...uide/Do check your manual, like the others have mentioned... If you don't have it, sign up over at mygmlink, it's free.
