Best way to fix paint chips?
UWAdventurer
Post by UWAdventurer »
OK, we want to fix the hood chips on our 2 month old car. Don't want globs, any suggestions? Thanks in advance everyone.
2005 Base Salsa Monotone w/ Gold pinstripe & Graphite Interior, 20%Tinted Windows, Automatic, Power Group, Moon & Tunes, XM Satallite, 16" Alloys w/Kleen Wheels & Splash Guards, ABS, FIAMM Air Horns, Side curtain air bags
newvibeowner
Re: Best way to fix paint chips? (UWAdventurer)
Post by newvibeowner »
I was told to use a toothpick and build the paint up and then let it drive and buff it or wax it. My car is 4 months old and i have 3 huge chips on the hood from rocks and of course I didn't get the touch-up advice before I did. I'm convinced the paint is also bad on the car.Hope this helps.sp
MoonDogg
Re: Best way to fix paint chips? (newvibeowner)
Post by MoonDogg »
Quote, originally posted by newvibeowner » I'm convinced the paint is also bad on the car.Hope this helps.spI bet your right... I had my hood repainted under warrenty because of chips and stuff.. they claimed it as weather hazard and got it repainted... check with you dealer..
2004 Vibe GT Fusion OrangeOptions: M&T, Monotone Paint, 35% TintMods: Kenwood Excelon KDC-X659 HU, Orion CS200.4 amp, Kicker Comp VR 10" sub, Megan Racing STB, Injen CAI, Magnaflow Cat-Back, brass shifter bushing, underbody orange neon's.
03VibeGT6Spd
Post by 03VibeGT6Spd »
I use a very small brush about the size of a tooth pick.I build it up then use a clear coat to make it even.The best paint I have found is the touch up bottles at walmart.They even have hard to find colors.If you do a good job you wont be able to see it.I figure I have over 100 chip's in my hood.You would think I live on a dirt road or drive the highway alot.If you need help with the touch up work, I'll do some demos at michigan meet.If anyone is interested!
Nik
Re: (03VibeGT6Spd)
Post by Nik »
I'm about to fix a bunch of small chips on my abyys GT. I'm going to bust out my air brush I think. I'll let you know how it goes. ( I realize not everyone has an airbrush, but it will be a good test anyway.)
