Nasal sound
Herb
Nasal sound
Post by Herb »
I have a problem that's cropped up in the past few months that seems to be getting a bit worse now.I'm getting what sounds almost like a 'nasal' sound when I'm driving, and it goes up and down in pitch as the engine revs up or down.Originally I thought it was the exaust as one passenger thought I had modified it. Since I had minor damage to the cat after hitting a rubber wheel chock a couple of summers ago I thought perhaps now something's given way.However I did notice recently when I turned off the vent fans the noise went away so it's probably not engine/exaust related.I thought if it's the HVAC then the noise should occur even when the engine isn't on, but it doesn't.I'm a bit frustrated at this and hope someone out there has an idea what's going on, or for that matter what I'm talking about.
Would you agree to debris acceptance? 2003 Vibe GTMods installed GM Top and Mid-Gate Spoilers, Cosmo CAI, TWM Short Shifter with Desert Eagle weighted shift knob, TWM Bronzoil Shifter Cable Bushings, Magnaflow Cat Back Exhaust, Unichip, Injen Billet Aluminum Engine/Sparkplug covers and oil cap, Optima RedTop Battery, Lineage Ground Wire KitAwaiting install: Energy Suspension Motor Mounts, DC Sports Header
Mavrik
Re: Nasal sound (Herb)
Post by Mavrik »
if you have a developing exhaust leak... it could be small enough it requires some load on the engine to be heard. It could change pitch to with the engine rev. My guess only though,
