Remote on Amp using 12v Ignition
Punchie
Post by Punchie »
Basically i am trying to install an amp and sub on my stock HU w/ M+T, and I need to know how to wire my line out converter correctly into my HU. I already know how to splice etc, but im not exactly sure which wires. I tried the Black/Yellow and Red/White intertwined wires and it didnt work. I believe these to be the Rear L and R speakers. Thanks.
Jahntassa
Post by Jahntassa »
Because you have the M&T, I believe you need to wire your line-output converter after the amplifier under the passenger seat. Do a search, there're posts with the pin-outs of the amplifier connections. The signal coming from the radio to the amplifier is not powerful enough to properly run the line-output converter.
russ257
Re: (Jahntassa)
Post by russ257 »
the 12 volt source for the radio. i belive it should be red. when the key is on the radio is on
'03 VIBE AWDPioneer AVIC-N1MOMO 6.5" componets in frontMOMO 6.5" speakers in rearJL e6450 six channel ampJL 12" w3 subAlpine 120W amp powering the sub
Jahntassa
Post by Jahntassa »
Red is the industry standard aftermarket color.. Otherwise, you want the Gray wire which is two pins in on the bottom row behind the radio.
