HELP HELP HELP!!!! strut problems!!!!!!
drummerdude
Post by drummerdude »
Ok, as you all know, i replaced my stock springs with some Sportline lowering springs. I blew my struts, yada yada yada... I'm replacing them right now, and i look under my car and i see a problem. Strut on the right... just fine. Strut on the left... BIG PROBLEM!!! The nut is not only loose, but gone. The bottom part of the strut (where it actually attaches to the wheel connection/hub/whatever) is about to just pop off the end of the shaft. I've got pics and will attach them. Any advice as to how i should proceed? Jack up the left side and let it pop off, take wheel off, then strut... so on and so forth. Also does anyone have the part number for the nutand washer combination that is missing? Thanks!!!Right side....
2006 MazdaSpeed6 GT which is for sale if anyone is interested...
drummerdude
Re: HELP HELP HELP!!!! strut problems!!!!!! (drummerdude)
Left Side....
MadBill
Post by MadBill »
Ah, the REAR strut! Couldn't figure which nut you meant. Just jack up both sides at the rear, starting with the left. The strut has an internal stop, so it will only extend so far, then the axle will continue to drop down until you can slide the strut back over the (hopefully undamaged) stud (maybe a few whacks with a soft hammer), get a new nut and this time tighten the %^# out of it! (check the other side for torque too)
satur9
Re: HELP HELP HELP!!!! strut problems!!!!!! (MadBill)
Post by satur9 »
proper torque,recheck,LOCKTITE!!.
drummerdude
Re: HELP HELP HELP!!!! strut problems!!!!!! (satur9)
Thanks guys for your advice. I did what Madbill said. I figured it out right after I got offline last night. I freaked out when I saw it. I had just hit 130+ racing a stupid v6 Grand Am. I'm lucky to be alive... I have a feeling that now I'll check those stupid nuts before I drive anywhere.
drummerdude
Re: HELP HELP HELP!!!! strut problems!!!!!! (silverawd26)
Quote, originally posted by silverawd26 »Congrats on getting your struts.... No offense, but you worried about getting killed because of the strut nut coming off?Doing 130 mph and racing is endangering yourself and others..... I would be scared of you myself....I was racing at 12:30 at night on a deserted highway... at 130 if that strut would have come off... yes, I would have been dead!
ALi3N
Post by ALi3N »
personally, i go more for the kamikazee aproach. Jack it up until it just pops off, then reattach with new bolt. with the weight completely off the tire it should be easy to manipulate the strut.
ALi3N aka Dj ViP3RThere is a force through the euphoric beat causing uncontrolablemovement of your body, I am that force. Take a journey beyond the limits of your mind.'Download Mixes:http://shlrm.org/DjViP3R/http://www.myspace.com/djvip3r Latest Mixes: 'Nightlife' & 'M0Ti0N -X-'Pimpin' Abyss Vibe GT w/ Nav
Mase
Post by Mase »
Now you got me worrying. I've had a "knock/creak" coming from the rear lately, but I have just been writing it off as my sway bar needing some tightening...but now I think I may need to check my struts! I also have Sportlines.
MoonDogg
Post by MoonDogg »
WHOLY *@#% I'm going check mine as soon as its stops raining.. that's scary as all hell... glad you fix it...
2004 Vibe GT Fusion OrangeOptions: M&T, Monotone Paint, 35% TintMods: Kenwood Excelon KDC-X659 HU, Orion CS200.4 amp, Kicker Comp VR 10" sub, Megan Racing STB, Injen CAI, Magnaflow Cat-Back, brass shifter bushing, underbody orange neon's.
DavidPIL
Post by DavidPIL »
Hi all...Dunno if this'll help but... http://p-car.com/torque/Dave
Turbo5Speed
Re: HELP HELP HELP!!!! strut problems!!!!!! (DavidPIL)
Post by Turbo5Speed »
Jesus, I'm glad you caught that before it caught you
ragingfish
Post by ragingfish »
LOL!Those are Posrche torques!I wouldn't trust them...it says 95 ft-lb torque for wheel nuts...the Vibe calls for only 76 ft-lb.
2009 PONTIAC G8
