The 03's are cable driven on the throttle body. The red line is about 8200-8400 at least it is on my 03 gt.
"Do not worry about your difficulties in Mathematics. I can assure you mine are still greater." AE"Science without religion is lame. Religion without science is blind." AE"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." AE
anyone know if the knock sensor is 2 or 1 wire? any variations between the vibe's 2zz and the celicas? does the apex power fc fit your harness? heh thanks!
I seem to remember reading that GM did the engine control electronics on the Vibes so they are different in that regard from the Toyotas. I can't say for sure that this applies to the parts in question, but you'll probably run into some difficulties putting the GM version into a Toyota.
Our ECU harness connector is different. I think fuel cut is 8350. cable throttle. They are toyota compatible.
