I've been reading through all the archives in regards to adding an amp and sub to a stock HU. I got the M&T w/ XM. I've already purchased a line level converter. What i need to know is should i grab the signal before or after the amp. Noticed it was done both ways in previous posts.TIA
before or else you will be amping the signal mutiple times. the m&T amp is not the greatest in the world you should get cleaner signal out of going right to your amp
'03 VIBE AWDPioneer AVIC-N1MOMO 6.5" componets in frontMOMO 6.5" speakers in rearJL e6450 six channel ampJL 12" w3 subAlpine 120W amp powering the sub
Quote, originally posted by russ257 »before or else you will be amping the signal mutiple times. the m&T amp is not the greatest in the world you should get cleaner signal out of going right to your ampYep, that's what I did. I knew it wouldn't sound as good coming out of the amp as it would be too much power and probably cause distortion.
