dash vibration
alk21633
dash vibration
Post by alk21633 »
I own a 2003 Vibe and every so often there is a vibration or rattle coming from the left dash. No , I do not have coins in that holder. Has anyone ele experienced this, and if so, rmedyplease.
platinum_
Re: dash vibration (alk21633)
Post by platinum_ »
i have for sure, i listen to it almost daily, but i did loose two screws behind the dash somewhere, i'm thinking its from them :S
alk21633
Re: dash vibration (platinum_)
Post by alk21633 »
Thank you. Unfortunately, I did not buythe car new, so Imhave no idea how longit has been there. I also have another, from under the hood. At times , when I go into reverse I heare a 'rattle", I am not even going there, Never happens in forweward. Alex
robdog
Post by robdog »
alot of people have dash rattles, it is very common, especially when the temps get cold in the winter. In the summer I never have a rattle, but when the temps drop in the 30's or lower it rattles alot, I guess the plastics all stiffen up in colder temps
03, Abyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.
Jahntassa
Post by Jahntassa »
It might be the rings around the gauges. I had a squeeking sound where the plastic would rub.. Ended up pulling the plastic /w chrome off the dash (just pulls off) and putting a little piece of thin cardboard right in the center bottom to prevent the rubbing.
alk21633
Post by alk21633 »
Thank you, unfortunatlymy rattle has occured this summer when temperatures were up. Perhaps this winter I will be rattle free.
alk21633
Re: (alk21633)
Post by alk21633 »
Thanks, this sounds easy enough to be worth trying.
spyder
Re: (alk21633)
Post by spyder »
I had my car at the dealer for the same problem. When I reved the engine above 4000rpm there would be a rattle from the dash. The tecnician at the dealer fixed it. The technicians report said "Tech cause: cowl screen loose - Tech comment: re & re rt side of cowl screen, shimmed & secured to corr noise. -Warrenty"So what ever the cowl screen is...was the cause in my car.Hope this helps!Spyder
Dave_ca
Post by Dave_ca »
I have a similar rattle on the left side of my vibe, but it only happenes when its below -10 Celcius. I think mine is comming from the area where the drivers door and dash meet. If I put my fingers down in there (very tight squeeze) the rattle stops immediatly. When I go for my 50k Maintenance I will get it and a few other minor problems addressed.
Re: (spyderpost)
Ahh, I can't wait until we can get these rattles figured out! Unfortunately, mine sounds different than yours. But it *does* snap, crackle, and pop very close to the cowl area. None of the engine speed-related stuff going on, however.Mainly dependent on chassis flexing (rough roads, etc.) on my car.
Image Image
