I just installed the Silverstar headlights, foglights and front turn signals. I was a fairly easy process. It took about 30 minutes to uninstall the stock bulbs and install the new Silverstar's for the first time. It would be dramatically less the next time knowing exactly what to do. I love the look from the front of the vehicle. The look from the inside of the vehicle is very nice as well. It is a brighter, whiter more spread out beam of light, where as the stock bulbs are a bright, yellowish and more direct beam of light. I also found a $5 mail-in rebate coupon on Sylvania's website. Here's the link: http://www.sylvania.com/Brian
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Quote, originally posted by BlueCrush »I just installed the Silverstar headlights...It took about 30 minutes...It would be dramatically less the next time...Keep your receipt, Blue! Unfortunately, "next time" is likely to be sooner rather than later! A number of GenVibers have Silverstars and love the light output, but not the bulb life. I've done better than most with 9 months for the first, 15 and counting for the second. PS: Did you have to shift the battery to do the driver's side? It depends on your paw size...
I did have to slide the battery over to get to the driver's side for the headlight and the turn signal. I was planning on keeping the receipt based on the bulb life listed in other threads.Brian
My Fleet:
I figured that the fogs would last longer than the headlights due to the fact that the fogs are on only at night while that headlights are always on.Brian
My Fleet:
Disable the DRLs and your headlights wont be on all the time. My sivlerstars lasted 8 months because of that I might swap out the driving lights fora set of projector fog lights.
I don't think it's been proven that DRLs have a significant effect on the Silverstars or not, but on the headlight bulbs, average time between failures is about 8 months. The foglights in mine are still going strong after 1.5 years. I switched to HIDs in the headlights, and I believe those were around $300 (I managed to trade Mike for 'em, thanks Mike!), his good ones were what, 400-500? But, you'll probably never have to change them. If you do, it might be once. That's worth the money for the better lighting and less frustration than new bulbs once or twice a year. Especially at around $20 a bulb.
Quote, originally posted by Jahntassa »I switched to HIDs in the headlights, and I believe those were around $300 (I managed to trade Mike for 'em, thanks Mike!), his good ones were what, 400-500? But, you'll probably never have to change them. If you do, it might be once. That's worth the money for the better lighting and less frustration than new bulbs once or twice a year. Especially at around $20 a bulb.As we all know, I did a full-out head/fog HID conversion, and that cost just under $900...I believe by the end of 2005, the HID's will have paid for themselves by what I HAVEN'T spent on silverstars!
