04' GT Injen CAI Installed
MoonDogg
Post by MoonDogg »
After many choice words, a smashed filter, taking the bumber off, and 3 1/2 hours later, the Injen CAI is installed and works perfect!!! The instructions from Injen are very good and I did not take enough pics to do a step-by-step, but I am going to say this... they never tell you to take the front bumber off, but DO IT!!! it is so much easier with the bumber off and its no hard to do. I will post pictures below .
2004 Vibe GT Fusion OrangeOptions: M&T, Monotone Paint, 35% TintMods: Kenwood Excelon KDC-X659 HU, Orion CS200.4 amp, Kicker Comp VR 10" sub, Megan Racing STB, Injen CAI, Magnaflow Cat-Back, brass shifter bushing, underbody orange neon's.
MoonDogg
Re: 04' GT Injen CAI Installed (MoonDogg)
Post by MoonDogg »
Here is the before picture.
MoonDogg
Post by MoonDogg »
Here is the kit in the box.
MoonDogg
Post by MoonDogg »
Here is a pic of the stock air box taken out.
MoonDogg
Post by MoonDogg »
Here is a picture of the vibra mount and the raised fuse box. I later fliped the vibra mount over.
MoonDogg
Post by MoonDogg »
Here is a pic of the bracket for the fuse box.
MoonDogg
Post by MoonDogg »
Here is a picture of a friend of mine tring to get the pipe to fit before we took the bumber off.
MoonDogg
Post by MoonDogg »
Here is a picture of the bumber off.
MoonDogg
Post by MoonDogg »
Here is a close-up of the bumber off.
MoonDogg
Post by MoonDogg »
Here is a picture of the intake together.... Almost done..
MoonDogg
Post by MoonDogg »
Here is a picture of the filter. Btw when you put the front bumber back on you will smash the filter but it just bends a little.
MoonDogg
Post by MoonDogg »
Here is picture of the complete install.
MoonDogg
Post by MoonDogg »
Ok last picture of install from futher away with bumber on. :-) Any Questions on how the install went don't hesitate to ask.
nismo
Post by nismo »
Nice install Moondogg. I installed a CAI on mine, my brother and I didn't have to take the bumper off at all. Yes, it was a tight squeeze under there, but we got the filter on without bending it. And it seems that on the GT's the filter sits at a slant. In mine, it sits straight, no curve at all. And I don't recall TRDVibe taking the bumper off at the meet to install Mavriks intake on his.Inder
2008 Chevy Cobalt SS Turbo - Fun stuff under there somewhere 1998 Nissan Sentra - Sold2004 Pontiac Vibe - 107k and SoldCosmo CAI
MoonDogg
Re: 04' GT Injen CAI Installed (TRD4reel)
Post by MoonDogg »
Quote, originally posted by TRD4reel »Nice install Moondogg. I installed a CAI on mine, my brother and I didn't have to take the bumper off at all. Yes, it was a tight squeeze under there, but we got the filter on without bending it. And it seems that on the GT's the filter sits at a slant. In mine, it sits straight, no curve at all. And I don't recall TRDVibe taking the bumper off at the meet to install Mavriks intake on his.InderDoes Mavrik have GT? and if so is it a 04' Cause the 03' is different it don't have the air pump that the 04' has... It was a very very very tight fit.
PhillyVibeGT
Post by PhillyVibeGT »
Quote, originally posted by MoonDogg »Does Mavrik have GT? and if so is it a 04' Cause the 03' is different it don't have the air pump that the 04' has... It was a very very very tight fit. I could not imagine the 04 GT install without taking the bumper off and having to deal the smog pump, I think it would be impossible. My directions from Injen did recommend taking the bumper off, and all the pics were of the bumperless GT. Glad to hear there is another GT owner with an Injen!
04 GT Satellite Monotone17'' Fittipaldi Fins on Falkin Azenis ST115'sMoon and Tunes/Sirius Satallite RadioInjen CAI/Magnaflow Cat-back Exhaust GM Top Spoiler/Debaged SilverStar Fogs "I wasn’t born rich, I’m good looking instead"
Raven
Post by Raven »
What a beautiful garage to work in. You make me very jealous. I installed my CAI on a gravel driveway infested with a million black flies buzzing around my head.
Mase
Post by Mase »
Were you able to get the rubber hose over the port on the air pump or did you just jam it inside like the instructions showed? I couldn't get it to fit over the port so I just jammed it in and sealed it with some black duct tape.You may want to get an extra nut to stack on top of the vibra mount. That'll keep it from backing off under the vibration. Mine backed off and the washer and nut ended up being lost to the road gods.Now go out and scare some people with lift.
MoonDogg
Re: 04' GT Injen CAI Installed (Mase)
Post by MoonDogg »
Quote, originally posted by Mase »Were you able to get the rubber hose over the port on the air pump or did you just jam it inside like the instructions showed? I couldn't get it to fit over the port so I just jammed it in and sealed it with some black duct tape.You may want to get an extra nut to stack on top of the vibra mount. That'll keep it from backing off under the vibration. Mine backed off and the washer and nut ended up being lost to the road gods.Now go out and scare some people with lift.Yeah we were able to get it over the port with one person holding the hose and pipe and the other with a flathead screwdriver prying it on. And with the vibra mount I have a nut on the bottom and top but I thought about it while posting the pictures I need to tighting them both down better...
MoonDogg
Re: 04' GT Injen CAI Installed (PhillyVibeGT)
Post by MoonDogg »
Quote, originally posted by PhillyVibeGT » I could not imagine the 04 GT install without taking the bumper off and having to deal the smog pump, I think it would be impossible. My directions from Injen did recommend taking the bumper off, and all the pics were of the bumperless GT. Glad to hear there is another GT owner with an Injen!(removed) I thought it did not exciste anouther 04 GT that has went through the pains of installing an Injen CAI!!! wow.. hey did you have to bend your filter to? If not how did you do it.??? If got pics please share!!!
nismo
Post by nismo »
Mavrik doesn't have a GT, but it is an 04 like mine. I have an Injen as well, and the install went very smoothly Inder
MoonDogg
Post by MoonDogg »
Does the base have the smog pump?
nismo
Post by nismo »
I don't think there is one.Inder
PhillyVibeGT
Quote, originally posted by MoonDogg »(removed) I thought it did not exciste anouther 04 GT that has went through the pains of installing an Injen CAI!!! wow.. hey did you have to bend your filter to? If not how did you do it.??? If got pics please share!!! Yeah the install was a real pain in the (removed)! While I had the bumper off I shaved a bit of the foam "bumper" away so that it had a few centimeters clearence. Sorry no pics.
PhillyVibeGT
P.S. Only the GT's have the smog pump.
syclnjr
Post by syclnjr »
So taking the bumper off is the way to go. how hard is it to get off? any alignment problems when putting it back on? Just curious as I will be doing this soon on my GT.
Mike2004 Vibe GT Abyss two tone, M/T, power package and 17's.
ragingfish
Re: (syclnjr)
Post by ragingfish »
Quote, originally posted by syclnjr »So taking the bumper off is the way to go. how hard is it to get off?http://forums.genvibe.com/zerothread?id=12551
2009 PONTIAC G8
MoonDogg
Re: (syclnjr)
Post by MoonDogg »
Quote, originally posted by syclnjr »So taking the bumper off is the way to go. how hard is it to get off? any alignment problems when putting it back on? Just curious as I will be doing this soon on my GT.Yeah that link posted about explains it much better than I can.. hell I wish I would of saw that ahead of time.. but yeah.. its pretty easy and would have saved me 1 to 1 1/2 hrs of time... good luck... and have fun with you CAI its awesome...
syclnjr
Post by syclnjr »
Thanks guys as always you are awesome
Merzbow
Re: (MoonDogg)
Post by Merzbow »
I had to take my bumper off to clean my filter at the beggining of winter. Since it was off and the filter was clean, the Cosmo tube was a little longer than I wanted it to be. It didn't hit the bumper or anything but the filter went way up on the tube so inside the filter the tube was withint like a half inch frmo the bottom of the filter if you hav eany idea what im trying to say lol. It's bugging me so I drew a picture. Anyways, I took a hack saw and trimmed the bottom of the CAI tube so the filter would recieve more air....heres the pic.
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
PhillyVibeGT
Re: (Merzbow)
nice artwork
Mavrik
Post by Mavrik »
Quote, originally posted by MoonDogg »Does Mavrik have GT? and if so is it a 04' Cause the 03' is different it don't have the air pump that the 04' has... It was a very very very tight fit. I have the 04 base but the design is the same on the base and the GT as far as the front end is concerned. No bumper removal required at all, just two bolts on the bottom of the front bumper were the inner wheel well fastens to the fascia. Pull back the inner wheel well cover and there you have clear access to install the filter. I had mine installed the first time in about 1.5 hours, the second time it took like 30 mins.
Merzbow
Re: 04' GT Injen CAI Installed (Mavrik)
Post by Merzbow »
I tried extracting mine via wheel well but it didn't work...when I re-oil it again in the spring it will probably come out like that since I trimmed the tube.And thanks for the artwork compliment
ragingfish
I'll likely trim the tube at the 60,000 mile maintenace...Taking off the bumper is easy, but a bit of a chore when i'm pressed for time...Would rather be able to nab it from underneath...
2009 PONTIAC G8
TheBri
Question Injen RD CAI
Post by TheBri »
I have the 04 GT so I have the smog pump. On the smog pump were the 17 mm hose goes and then runs up on to the CAI pipe after the filter, on the stock one it was before the filter. Does the smog pump suck air from the CAI pipe? because my smog pump were the 17 mm hose goes had dirt inside it and I don't want the CAI sucking that up into the intake. Also the front side air valve, do you disconnect it electricaly? and then put the cap on at the "T" plastic part? Other than that I think I am good for the rest of it. Can't wait to get it on and then hit some sweet lift!
J-freakie
Post by J-freakie »
Did you by chance get a by pas valve? I strongly recomend getting one, the worst thing that could happen is that you get water in there. Just about the most common problem with the cai. Good pics though Too bad they weren't big enough dan
"I will no longer talk to my wife just as long as there is a TV in this house". Al Bundy
