It's definitely been done at least once (on an AWD Matrix), but it voids the factory warranty. Why? The long-term longevity of the AWD driveline components isn't assured with the approximate 30% increase in horsepower and torque with the supercharger.Toyota and GM don't want to replace the fairly expensive Matrix/Vibe AWD drivetrain components under warranty if they get trashed by the extra torque and horsepower supercharger, so they don't warranty that combination.Neither GM nor Toyota offer the supercharger INSTALLED from the factory. On a manual or automatic Front-Wheel-Drive Vibe or Matrix with the 1.8 1ZZ engine (but not the 2ZZ GT/XRS engine), the supercharger is a dealer-installed add-on at the time of purchase (and then carries the same warranty as the rest of the drivetrain.) If you install it yourself, I believe the warranty is 12 months/12,000 miles on one of the warranted models, but not AWD.User 'Greenfire' (User Profile -->
http://forums.genvibe.com/zero...d=753) HAD an AWD Matrix with TRD supercharger. He eventually blew his supercharged engine, apparently because of a severe lean condition caused by an aftermarket performance chip problem, definitely NOT anything to do with AWD. In any case, he had to cough up the money for another engine out-of-pocket. OUCH! I believe he chose NOT to supercharge the replacement engine. Genvibe thread -->
http://forums.genvibe.com/zerothread?id=12567. The first post in the Genvibe thread has links to the full details in the relevant forums of Matrixowners.com.If you have performance shop contacts who regularly do mods on the 1ZZ Toyota engines, transmissions, and (hopefully AWD drivetrains), I'd say GO FOR IT. An unlimited supply of money would also help! Welcome to the Encyclopedia of Vibe, by the way!
