Will 20" rims fit?
Mr. Poopypants
Will 20" rims fit?
Post by Mr. Poopypants »
Will 20" rims fit on a Vibe?
pissedoffgokart
Re: Will 20" rims fit? (MFFenton)
Post by pissedoffgokart »
Sure they will fit but, you'll have to use a rubber band as a tire!!!!
Sub-Vibe-R
Re: Will 20" rims fit? (pissedoffgokart)
Post by Sub-Vibe-R »
And gt ready to pay a lot for them
andrewmva
Re: Will 20" rims fit? (Sub-Vibe-R)
Post by andrewmva »
currently the smallest tire on the market in 20" is a 245/35/20 too big!! - But I have head rumors that there will be smaller sizes out soon... you COULD fit them with some modification to the fender wells.... -BUT the Major issue is that there really is not any 20" wheels with a 5X100 bolt pattern!!! only a select few... it would take some work!!!
E-Man
Re: Will 20" rims fit? (andrewmva)
Post by E-Man »
Andrewmva,I see the pics of your matrix and it looks good with those wheels. Might I ask the brand, size, and price. Also if they are 18" -- have you noticed any degradation in ride quality compare to the original 17" or 16" wheels.ThanksEd
Monotone Salsa Vibe
andrewmva
Re: Will 20" rims fit? (E-Man)
Post by andrewmva »
they are 19" Axis Hagan w 225/35/19 Yokohama Parada spec II you can use 235/35/19 -my car is lowered alot.... the ride sucks... -but I only live about 2 miles from work... you get used to the ride being poor and adjust.... the look makes up for it... my car turns heads EVERYWHERE.. there are not too many in that color in the area and NONE that low w/ 19" wheels.
Sub-Vibe-R
Hey Andrewmva,I'm thinking about upgrading my stock tire. I think to go with 225/45/17. Should I take a less wide tire like 215 or 205?
MadBill
Post by MadBill »
As far as sizes go, there is excellent data on The Tire Rack's site: http://www.tirerack.com It takes a little chasing around to find eveything, but when you click "specs" for a tire, you get a list of available sizes. They list all dimensions, including revs per mile, so you can match diameters to keep the speedo in calibration, and width, so you can decide what "might" fit without too much hassle. Also, required rim widths, so you don't buy a 265/30 to pop on your 7" rim. (Speaking of which, when I checked they had 56 wheels for Vibe!)
andrewmva
Post by andrewmva »
Sub-vibe-R I honestly have no idea... I dont even know what the stock tire size is.... I drove my car from the dealer to the shop and put on the 19" wheels.........
Sub-Vibe-R
thanks anyways
Mr. Poopypants
quote:currently the smallest tire on the market in 20" is a 245/35/20 too big!! - But I have head rumors that there will be smaller sizes out soon... you COULD fit them with some modification to the fender wells.... -BUT the Major issue is that there really is not any 20" wheels with a 5X100 bolt pattern!!! only a select few... it would take some work!!!I would like to put 20"s on but I don't think I am willing to modify the wheel wells. I'll deal with the stock 16"s until something different comes along.
