Quote, originally posted by vibe_commander ».....I'm looking for more torque. With Blitz's supercharger still in development for the Matrix (not to mention how expensive it is!) adapting a 1zz supercharger seems like a reasonable way to achieve better torque gains. Has anyone seen any other superchargers that would work with a 2zz besides Blitz?Gee, the 2zz motor is just not a torque monster. Remember , I have a turboed 1zz, and I have ridden in a turboed 2zz. The 2zz just doesnt throw you back in your seat the way the 1zz does under boost. The 2zz , though, is a great motor and is superiour to the 1zz in so many ways. It is built for performance. It has a forged crank, the rods are beefier. The cam profiles are just awsome....I mean, look at the Lotus elise. It is a 40k sports car, and it is fitted with the 2zz !!Anyway, here are some observation about F/I.
http://www.turbo-perfomance.comThey have a turbo kit for the 2zz celica GT-S..It has a garrett t3 turbo, an intercooler and runs on 5psi. There is no new engine management. What that tells me is that the ECU and injetors will supply enough fuel up to 5 psI. I believe that it is important to note that the turbo they use spools up after 3k, and puts the ECU into open loop while boosting. AND, the air is intercooled.SF always told me that turbos are torque multipleirs. If you gain 50% mor HP, you will also gain 50% mor torque. I would get the SF Vibe GT kit when it comes out. Everything is made to fit , and has been tested to work. BUT I mention the other stuff to say that you could do a custom job and keep the boost at a low 5psi and have a kit on your car as worthy as the TP kit. The blitz SC kit is just too much $$ for what you get......I would get the SF kit.
pics 10/2/05
http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
