loose gas fill
giomshadow
loose gas fill
Post by giomshadow »
does anyone experience a loose gas fill...I find when getting gas (which is pleasantly infrequent!) that the gas spout wiggles...had not experienced this with other cars...thanks
giomshadow base, moon 'n tunes, anti-locks, side airbags,first aid/ storage packs, gear box, cargo mat, rear bumper strip and 16x7 Mille Miglia MM11-2 Silver
NSimkins
Global Moderator
Re: loose gas fill (giomshadow)
Post by NSimkins »
It's the same on all Vibes. There is rubber around the filler hole/tube area that causes it to be flexible. I've seen other vehicles with the same setup.
giomshadow
Re: loose gas fill (NSimkins)
thanks...was wondering if a bolt was loose...
