Soooo we all know nitrous is expensive but affective. Well what about CO2 injection into the intake? I heard that you can inject it into your CAI and bring the temp of the air down to like -30 or something like that? Not sure how affective this would be on performance but it would sure sound cool (removed). My friend and I were thinkin about doing that and then buying some purge valves to install in the wheel wells so it looks and sounds like nitrous lol. I know it's a little ricey with the purge valves but I think it would be awsome as hell.
I don't if you'd cover enough surface area on the intake to get the air to a noticeably cooler temp if you just sprayed the tube. I've seen people freeze their intercoolers with a fire extinguisher before going on a drag run. That may work.There's a company that makes intakes with a dry-ice box built around the tube and they claim moderate gains.
there is a bulb that goes into the intake. the co2 sprays into that and the air flows across it.mabey good for 5hp or so
satur9 is right..its a cry02 system i have one just not in my car yet..i have a post alittle while back about it..just waiting for my bodykit. itll look alot better..a coupl eof my friends have it and it is a difference that u can feel. i would definatly recommend it. and if u want the purge system also then u have to buy another switch or else it will go off into the intake when u want to just have the purge going off and vice versa...also for the c02 u can get it at any paint ball shop when u run out..its 1 bucka lbs.
My Car, with the kit on. it looks awesome! come and check it out, tell me what u think.P.S. the gray will be painted momentarily http://www.cardomain.com/ride/514882/1
well u can check out some sites the prices very....the kits are kinda price but worth the power and reactions of the people who c it happen!
I think I'll just order a NX 10lb bottle and use that to fill it instead of paying $100 for the cryO2 canister. We will just buy everything seperately.
Quote, originally posted by Merzbow »I think I'll just order a NX 10lb bottle and use that to fill it instead of paying $100 for the cryO2 canister. We will just buy everything seperately.I would not mind spraying this stuff on my intercooler hmmm...I am just getting greedy now!!!
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
Quote, originally posted by TRD4reel »Hey man, the more power, the better. InderYeah, I guess so.....this kind of thinking is gunna get me to blow up my motor!!! Its thirty degrees outside right now where I live...and its very dry ...Man, the turbo loves cold weather!!!..tires are breaking loose in the 1st 3 gears.....
Hopefully in about 2 years I'm gonna turbo my GT with a full engine upgrade the guys at monkey wrench said they could probably manage 425 ish hp for $10,000 plus like another $3,000 for beefing the transmission to handle it. Need the warranty to run out and then make a few extra grand and I'll be set
Quote, originally posted by Faultline »This kind of thinking is gunna get me to blow up my motor!!!A cheap CHEAP way for you to make more power safely would be to go with Water Injection...and use the HUGE *FOUR LITER* windshield washer fluid tank as your reservoir....I'm sure it's 2" below where you'd be injecting...http://co.dsm.org/tech/waterinj.html(Keep in mind that Colby hacked the *HELL* out of his front end - most Water Injection installs are tidy and clean...*grin*)The Colorado DSM club also has more information on drilling the DSM Wiper Fluid reservoir for using in a Water Injection setup that I'll see if I can dig up if you're interested. I know guys that have done WI setups for $50 that use parts from Home Depot... (Hell, I was working one up for my *stock* Talon...*grin*)Another advantage to using the Wiper Res. is that Wiper Fluid is 49.5% Water, 49.5% Alcohol, and .25% Blue Coloring...and the Alcohol vaporises (and therefore *COOLS* your intake charge as well, or better than, the water does...)Drop me a line if you're interested... I'd love to turbo my GT (mildly) with the pile of knowledge that I gained from owning the Talon...but the $3000 entry fee to join the Turbo Vibe Club is a bit steep...
