I bought foglights from Canadian Tire $69.99 and installed them without any difficulty in an hour or so.I found after using my fogs like this that the light spread wasn't great so I've rotated them 90º. I made two small square blocks 3/8" thick from a piece of aluminium plate, drilled a hole to allow a screw to pass through that would line up with the existing hole in the fog light housing. The blocks are just a spacer so that the mounting bracket can pull down solidly. Once I had the parts together it took me about 1/2hr to do the modification.I've used them for a while like this and find that the light spread is much better.
Attached files Foglightinstallation.ppt (230 KB)
