hey guys, i have a 2003 GT , with the 17" Rims, what is the size of the tire? and the width ? i have looked around and cant find exactly which winter tires to get, i found a calculator so i just need the original size thanks.
hey, platinum. if you do a search, you'll find a LOT of threads on this. in fact i just posted in one last night on the same exact question on which winter tires to get for the 17" wheels. are you keeping them on the 17's or you going with 15's or 16's like most of us have?
thats for the reply, but it doesnt say the actual size anywhere for the GT 17" option, i only foujd this : "I currently have factory 215/50-17's" , but am not sure if it is the same size as the GT, i am looking to put on some steel 16" , and will find the appropriate size if i can figure out the size of the ones i have now, thanks.
Quote, originally posted by platinum_ »i used the calculator and i think i've found the perfect size for my vibe. P205/65R/15 , the calculator shows a 0.1% difference from the P215/50R/17 :Di believe those are the same size wheels i have. i posted it up above if i remember correctly.
Quote, originally posted by trdvibe »i believe those are the same size wheels i have. i posted it up above if i remember correctly.oops, sorry, i posted it in another thread:Quote, originally posted by trdvibe » depends on what rims you are going from... 16" or 17"?i have 17" OEM rims and tires and went with 15" steelies and 205/65/15 studded Hancook snow tires. the 60 was not close enough in diameter.also see this similar thread: http://forums.genvibe.com/zerothread?id=6398
