Injen CAI question.
Celtic_Curse
Injen CAI question.
Post by Celtic_Curse »
HEy everyone...searching for this but couldn't find the info. Does anyone know what the diameter is on the Injen CAI I'm going to be buying a new filter and need to know what the diameter is. The Flter I'm buying comes with a heat shield and haven't got a clue what diameter the pipe is. Any help would be appreciated.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
ragingfish
Re: Injen CAI question. (Celtic_Curse)
Post by ragingfish »
IM NSimkins...he and I were discussing that just recently...not sure what the answer is though...
2009 PONTIAC G8
NSimkins
Global Moderator
Post by NSimkins »
When I ordered a replacement filter for my Injen CAI from PTuning, the default filter that they recommend is the PTX-1013 which is for a 2.75" Mouth. This is for a Base model Vibe CAI. The GT model Vibe CAI also states a 2.75" Mouth.I was unable to find any other specs on the diameter and I forgot to measure when I had the filter off a couple months ago.Hope that helps.
Celtic_Curse
Thank you very much, I'm going to buy a new one then slip it on then recharge the second one for the next filter change.
celica girl
Re: (Celtic_Curse)
Post by celica girl »
You don't need to have two of them... it doesn't take long to recharge a filter. I have a kit you can use.
wicked1981
Re: (celica girl)
Post by wicked1981 »
Quote, originally posted by celica girl »You don't need to have two of them... it doesn't take long to recharge a filter. I have a kit you can use. I usually do it on a Saturday night before I go to bed and let the filter sit overnight wake up put it on and done.
