well as you know.the cheapos as gm decided we didnt need cloth door panels on our rear doors.well thank to http://www.car-parts.com and some poor souls wrecked matrix. i now have four matching doors(and armrest,steering wheel,etc.) let the modding continue.
Nice! Matching everything! Very cool site, btw - been looking around for some parts I need... Thanks for posting the link, that may just come in handy!
Quote, originally posted by Merzbow »mine didn't come with rear cloth doors!!! I didn't even know it was an option.It's not an option for our car... The panels are from the Matrix.
yep exact fit. i dont have a camera.but you dont really need a picture do you?!?
i am curious how you got the panel off. in fiddling back there this weekend, it looked to me like it was melted or fused palstic knobs holding that on?
door panels are easy clip ons. start at the front, then work your way back at the bottom. then the "pull" it up. p.s. the entire door panel has to come off.
if the rear door panels are contructed the same way as the front. then the insert should have "points" that are melted onto the door panel. not really sure what would be the best procedure to do this. maybe a solder... bu like i said.. those panel inserts are not clip onthen again, i could be wrong, not
you have to carefully drill the center then cut or grind off the melted plaastic. then epoxy it back. but mine are the whole door panels cause i couldnt find the inserts separetly. yes that cloth is the same as front the picture is just crappy
