While working on project "Boston," (codename for my current mod project), I took the time to reroute the wiring for my XM antenna. I removed the FM antenna base, dremeled out a whole, and ran the XM antenna through the base...I just need to find some sort of sealant now so I can stop the rain from getting in. It rained last night unexpectedly, I had to run out and put a plastic bag over the antenna to try and divert the rain away from the base. Hope my headliner isn't soaked this morning. Pix: The quick fix:
It'll work anywhere, pretty much. I actually used some to seal up the StreetGlow 20" neon tube behind my front grille.
Picked up some windshield sealant silicone today...it's clear, should do the trick...there were like 8 diff kinds of silicone, was unsure which to get, so i went for the cheapest. *shrug*That means ripping out the headliner yet a third time this week!
Looks nice. That's the way i'd go if i put in xm. Good job.
Car: Two-tone Base Abyss, Moons and tunes, Power packageMods: 20% tint, Reflective Black GrafxWerks Overlays, German Hella Horns, Hardwired Valentine One, red interior dome lights, custom cargo floormat, police scanner, ham radio, cellphone kit and a bunch of antennas on topWishlist: Rubber floormats, million dollars
I might end up doing the same.. since i've gotten my FRS radio again, gotta figure out where to put that antenna..
I didn't HAVE to reroute it per-se...but before I had it going down into the groove between the hatch door and body, then it snuck under the rubber grommet for the rear window washer fluid nozzle...I just feel it looks much more professionally installed this way...
Quote, originally posted by ragingfish »I just feel it looks much more professionally installed this way...It does look great! XM (or maybe Sirius) is still on my wish list.... may just "borrow" your idea.
Quote, originally posted by GMJAP »It does look great! XM (or maybe Sirius) is still on my wish list.... may just "borrow" your idea.Thanks!I'm really pleased with how it came out...And it POURED all day today...so it'll test my sealant job....Will pull down the rear of the liner tomorrow to check for water signs...but I think I'm clear...
