Max RPM @ 6400?
bjlarson
Max RPM @ 6400?
Post by bjlarson »
I have a 2005 AWD and I was cruisin' around today and noticed that my rpm would not go above 6400, no matter what I tried. Is there a restriction on the max rpm that an AWD can handle? Isn't redline at 8300?(not that I'm going there)Thanks!
2005 Vibe AWDMonotone Neptune BlueMoon & TunesK&N FilterchargerDynomax ST MufflerWish List: Unichip
nismo
Re: Max RPM @ 6400? (bjlarson)
Post by nismo »
Yeah. There's a beautiful thing which we call a rev limiter.Inder
2008 Chevy Cobalt SS Turbo - Fun stuff under there somewhere 1998 Nissan Sentra - Sold2004 Pontiac Vibe - 107k and SoldCosmo CAI
MadBill
Post by MadBill »
The GT can rev to ~8300 RPM; the rev limiter for the base engine is ~ 6300-6400.
bjlarson
Re: Max RPM @ 6400? (MadBill)
Post by bjlarson »
Got it!
Mavrik
Post by Mavrik »
Quote, originally posted by MadBill »The GT can rev to ~8300 RPM; the rev limiter for the base engine is ~ 6300-6400.unless you have a base manual transmission... it revs higher then that, my rev limiter hits in if I remember correctly (only tried once) in the 7000rpm range
VibeChick
Re: Max RPM @ 6400? (Mavrik)
Post by VibeChick »
I'd be surprised at that. It should be the same. Mine kicks in at precisely 6400 rpms. And I've tried it many times.
Used to have: 04 Monotone Abyss 5 SpeedNow the proud owner of a black 2005 SRT-4230 Hp250 lb/ft torque
Mavrik
Re: Max RPM @ 6400? (VibeChick)
Post by Mavrik »
Quote, originally posted by VibeChick »I'd be surprised at that. It should be the same. Mine kicks in at precisely 6400 rpms. And I've tried it many times. weird, I know mine was at 7000rpm, I had a mechanic with me at the time, we took it for a drive after he did the alignment from when I installed my springs... oh well lol... so carrie how often you redline? every shift?
VibeChick
Post by VibeChick »
Quote, originally posted by Mavrik »weird, I know mine was at 7000rpm, I had a mechanic with me at the time, we took it for a drive after he did the alignment from when I installed my springs... oh well lol... so carrie how often you redline? every shift? How often? Gee, sometimes I do it several times a day...but with snow on it's way this weekend, I think the fun driving is over for now
Celtic_Curse
Post by Celtic_Curse »
I have my shift light set at 6200RPM because the limiter kicks in at 6400RPM as well.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
MadBill
Post by MadBill »
Quote, originally posted by Mavrik »weird, I know mine was at 7000rpm, I had a mechanic with me at the time, we took it for a drive after he did the alignment from when I installed my springs... oh well lol... so carrie how often you redline? every shift? Wow! we need to clone your ECM, Mavrik. Most of us base 5-speed pilots would love to have a 7,000 RPM limiter! (unless your tach just has a huge error...) (mine's 6,400 also )
bobsbase04
Post by bobsbase04 »
There is a way to remove your rev limiter. I'm sure you can put some type of rev limiter in it, after removing the crystal in your ECU. Also check this out. Bad damge to engine with no Rev limiter:http://www.newcelica.org/forum...26792
MadBill
Re: Max RPM @ 6400? (bobsbase04)
Post by MadBill »
Umm... I don't think you could change a chrystal in the Vibe computer to raise/eliminate the rev limiter. I think new values have to be input to the tables in the engine computer, or add a 'piggyback' user-adjustable computer. Agreed, eliminating it is just asking for trouble; sooner or later you'll miss a shift, lose a clutch, etc., then: BOOM! However, best acceleration requires shifting somewhat past peak power RPM (which seems to be ~ 6,000 to 6,200 on a Base Vibe, per various actual dynomometer graphs), to keep the RPM nearer the peak, so a 7,000 RPM limit would be about right, and I believe is factory programmed in some applications of this engine.
nismo
Post by nismo »
I know if I'm in a race, the RPM's will only go to 6200 and then the next gear and so and so forth.Inder
nismo
Re: Max RPM @ 6400? (TRD4reel)
Post by nismo »
Well, I tried the rev limiter last nite. It cut in at 6700 RPM.Inder
Project Shadow
Post by Project Shadow »
So is there a safe increase us base people could change to with programming? Mine cuts out at around 6400 but definatley not over.
Shadow two tone, 5 speed, 16" alloys, power group, ABS safety group, 6CD, 200watt. Love the car.
03VibeGT6Spd
Post by 03VibeGT6Spd »
Are you guys saying that on the 1zz's there tach shows the same redline as the 2zz's.That would be tacky, or at least serious tease.
AKLGT
Post by AKLGT »
Quote, originally posted by Mavrik »weird, I know mine was at 7000rpm, I had a mechanic with me at the time, we took it for a drive after he did the alignment from when I installed my springs... oh well lol... so carrie how often you redline? every shift? that is strange since it's supposed to kick in at 6400 rpm. i know when my engine is cold in the GT, rev limiter hits about 7000 rpm.
AKLGT1998 Subaru 2.5RS
nismo
Re: Max RPM @ 6400? (trdvibe)
Post by nismo »
Well, I tried mine, and yes, the rev limit on mine is like 6400-6700. Somehwere in that area. But I'm pretty sure it's 6700.Inder
rubberman
Post by rubberman »
On my 91 Si i have the computer chipped it raised the limiter from about 6800rpm to 7200rpm.
Car&Bike Pics http://www.cardomain.com/ride/2355922/1New Kumho712(summer225/50/16)195/65/15 Dunlops(winter)03 Vibe 49,000kms gone!!!!!New Battery/window rubber pass doorTwo seats fixed(coming apart at the seams)Transmission?,Tires that sound like mudders on a truck(Contis) 18,000kms done/noisey A/C Compreser/poor paintRadio(no am)2 days old ,door speaker replaced
