Who has made one of these? I made one and here is what it is made out of...2 feet of 2 inch dia. PVC or ABS pressure rated pipe 1 foot of 3 inch dia. PVc or ABS pressure rated pipe screw off end cap for 3 inch pipe (note: clean out plug may be used) slip to threaded 3 inch fitting 3 to 2 in reducer PVC or ABS cement (note: do NOT mix PVC pipes with ABS pipes or fitting, only use PVC cement on PVC and ABS on ABS) BBQ ignitor 2 drywall screws hair spray/WD40 or starting fluid plenty of spuds The attached pic is not me or mine but similar and these things are a blast.
