I have installed a lightning audio amp and 10" dual sub. I hooked up the wires, red to battery, black to ground, blue to a manual switched positive.I then went under the seat and spliced into the yellow and black A4 and A5 pins and ran speaker wire with a RCA plug to the input on the sub amp.WOW it sounds great. now my problem:when i turn the key on everything is fine but when i start the car I don't get any sound anywhere, untill i unplug the RCA plug at the input at the sub amp and plug it back in then everything works.any ideas?
