Arrgh, wish I could offer you some suggestions from the software side, but after completely abandoning Windows for Linux back in the Win 2K era, I just can't. But you've received some good advice from the folks here who know this stuff zillions of times better than I. I like ebslopp's idea of the laptop hard drive adapter... That may be your best bet. Something similar to this:
http://www.compusa.com/product...=cat3Take out your laptop's hard drive, and if it is held in by in some sort of bracket, you'll remove that... Connect the laptop's drive to the adapter, connect the other side of the adapter to an IDE cable in your desktop. Boot up, and you *should* be able to see the drive on your desktop. I've used these in the past, works pretty well. As long as the drive itself isn't trashed, you should be able to pull off your files without too much hassle.Along the same lines (sort of) something like what I just bought may be helpful... I had an extra laptop hard drive laying around, so I bought an external USB enclosure for it. Just had to install the drive in the enclosure and connect the cables (one to the USB port, and one to the PS/2 keyboard port for power.) Works like a charm. Something like that may not be very useful for you though, if you don't have an extra laptop drive laying around to use once you're done with recovering your stuff from the laptop. Here's what I bought:
http://www.dealsonic.com/kikhalusb20e.htmlThe Linux live CD may work... If the file system used on the laptop is FAT, you'll be able to see it fine. If it is NTFS, you *should* still be able to mount the partition, but it will probably be mounted read only, which is all you really need for this situation anyway. Then, you can find a way to get your stuff to your other box, via the network using Samba or something. That could probably be a bit more difficult than just getting an adapter and slapping the laptop's drive into your desktop.Regardless, once you get your files retrieved, I'd say nuke it and start over. Good luck to you!
