HeadLight aim..........
Pump233ca
Post by Pump233ca »
Took some tinkering...but finally got the Headlights pointing in a comfortable position....I can`t believe this hasn`t come to the point of Service Bullatin...I realized that the light pattern is very similar to that of some H4 Quartz Lights I had some years back....anyways the they shine further down the road.
ragingfish
Re: HeadLight aim.......... (Pump233ca)
Post by ragingfish »
Where is the adjustment for them? I looked EVERYWHERE behind the lights, and couldn't find anything. The ONLY thing I could find was a screw that had teeth coming down from it, but it was SO far down, I couldn't reach it, and figured that wasn't it....advice please!
2009 PONTIAC G8
NSimkins
Global Moderator
Re: HeadLight aim.......... (ragingfish)
Post by NSimkins »
quote:Where is the adjustment for them? IThere is an adjustment screw behind each headlamp. See this thread for more info:http://forums.genvibe.com/zerothread?id ... =6195#6195
ragingfish
Re: HeadLight aim.......... (NSimkins)
I'm gonna run on the assumption it is the screw I saw...if that's the case, how can you get to it on the passenger side if you have ABS? I have the ABS boxey thing there with tons of tubies coming out of it, I can't get to that screw without hitting them. Thoughts?
2009 PONTIAC G8
NSimkins
Global Moderator
Post by NSimkins »
It's also a bolt (and you can use a stubby screwdriver).. you can use a socket w/ rachet to get into the tight space. That's what I did, but I don't have ABS.
mu_ohio
Post by mu_ohio »
I would suggest not installing a CAI before aiming your lights. I just tried to do mine and the passenger side is blocked by the tube. Guess I'll try using a screw driver later.
2004 Pontiac GTOPhantom Black w/black leather
ragingfish
Re: HeadLight aim.......... (mu_ohio)
what's a CAI?
2009 PONTIAC G8
CrazyJ-GT
Post by CrazyJ-GT »
CAI = Cold Air Intake
----------------JustinAbyss Vibe GT - Monotone, Moon & Tunes, 16" Wheels, & Power PackageMods: TRD Cold Air Intake, MagnaFlow Cat-Back Exhaust, and Hotchkis Lowering Springs.
ragingfish
Re: HeadLight aim.......... (CrazyJ-GT)
Did I miss something? Did anyone mention a cold air intake? LOL! I think you have the wrong thread, but I could be wrong.
2009 PONTIAC G8
NSimkins
Global Moderator
Post by NSimkins »
quote:Did I miss something? Did anyone mention a cold air intake? LOL! I think you have the wrong thread, but I could be wrong. No, mu_ohio stated that the presence of a CAI will affect the aim adjustment of the driver's side headlight. Then you asked what CAI stood for and CrazyJ-GT responded with an answer. Everything looks ok to me.
ragingfish
i get it now...he was just throwing that out there as a general thought...don't mind me all, i'm just a little slow on the uptake.
2009 PONTIAC G8
