Hey guys, i am wanting to purchase the bellow set, and notice that hte output is 4x60watt, giving me 240, rather than 200 from the 200watt amp under the seat, and i am thinking there should be no problem at all with the speekers unless i turn it up to max. What my question is, how would i connect the two head units toghether, and have the one with the amp be hooked up to the 6 speakers ( i read of a cross wire or something to the tweeters) , and skip the amp .. or if easier, how do i hook them upto the vibes amp ?? Thanks in advance for your replies. In-Dash Monitor w/ AM/FM/TV Tuner - Pyle PLTVR5 * Eject/Flip-Up LCD 5" Monitor * AM/FM Receiver & CD Changer Controller * In-Dash Unit Appears To Be Standard Car Radio * VHF/UHF Tuner * RCA Jacks For Easy Hookup Of Video Player Or Video Game System * Audio & Video In & Out, * TV/AV Switch For Easy Switching Between Sources * Full Function Remote Control * Controls Pyle® PLCH6D, PLCD10CH, And Other CD Changers * Maximum Power: 4 x 60 Watts * Antenna Not Included In Dash DVD/MP3 Player - Pyle PLDVD140 * MP3, DVD, CD-R. CD-RW and SDVD Compatible * Wireless Remote Contol With Remote Infra-ren Eye * In-Dash Mounting Kit and Brackets * Cigarette Lighter Adapter * 12 Volt DC Power System * RCA Audio Outputs * Multi-Langauge On-Screen Menue System * NTSC/PAL Compatible * Frequency Response: 20Hz to 20KHz * Signal-to-Noise Ratio: Greater Than 90dB * Dimensions: 6 5/16" x 6 3/16" x 2"
I'm not sure. The audio pros don't usually come on 'til later. You should have an answer by tomorrow morning I would expect. Welcome to Genvibe by the way! Make sure you try the search feature, there is a ton of info on this site!
--------------------------------------------------------------------------------2004 Base - TwoTone Neptune - 5 speed There are 10 types of people in life. There are those who understand binary and those who do not.
thank ebslopp for your reply, but to you audio pros i would really appreciate any advice , and i have found one more problem, it seems that no matter when, wether a cd is playing, or about to play, or not ... i hear a constant "shhhhhhh" from the speakers and its really starting to anoy me, its not always as noticable as it is when a song isnt playing, but i can always hear it just enough to anoy the hell out of me. if anyone has any insight on this too, please reply
Assuming you have M&T, you'd want to bypass the factory amplifier, but if you do that, you'll also need to replace your speakers.You'd get better sound running off the headunit, but you'd fry the headunit by connecting directly to the factory M&T speakers.I'm assuming you just removed the factory in-dash radio and installed the Pyle unit? If so, it could be a negative interaction between that and the factory amp.My advice: Get new speakers, bypass the factory amplifier. You'll be much happier.
nono, the original 1cd is still in there, and i do have the amp under the passenger seat, but why would i need new speakers if the pyle head unit is 4X60 Watts (240 total, 40 more than the vibe amp)
So wait. You still have the factory CD player, AND the Pyle unit? Or no?If so, how do you have that setup running?The Pyle headunit is designed to run 4 speakers at 4 Ohm each. The M&T speakers are 2 Ohm apiece. Headunits are not designed to take less than 4 Ohm speakers.Less resistance (Ohm), means the amplifier can put out more power. Which is why the factory M&T system uses 2 Ohm speakers, it takes less work for the amplifier to make more sound.If you connect 2 Ohm speakers to a radio that expects 4 Ohms, you'll likely fry the internal amplifier before long, if it doesn't fry immediately.So what we really need to know is what you have connected and how..
oh, sorry i didnt explain, i still have the original cd player in there, and am trying to figure out the best way to set it all up, i really dont want to change the speakers so if you know how i would go around setting it up using the M&T amp that would be great, thx
