My 2003 Vibe GT With 17" tires is cupping on the inside. I noticed the cupping when I had the tire rotated and balanced. I had Sears check the alignment and they told me is was right where it need to be. I took it to my local dealer and they told me i wasnt properly rotating the tires. I am a person who takes pride in my cars and perform the proper maintenance. Has anyone else had the same problem? The car has 26000 and there telling me I need new tires. Mark
My Conti's cupped really early on. Diagnosis: failure to rotate at exactly every 10,000 km (6000 miles). I think I went 15,000 km before I first rotated them, and they were screwed.I suffered through them until they were completely bald, then bought Pirelli's.
2003 Satellite AWD Two Tone, traded off at 180,126 kmNow the (fourth) catalytic converter is someone else's problem Now driving a 2007 Dodge Grand Caravan
My ancient 275/40 Firestone Firehawks have been on the same corners of my Vibe for over 30,000 km (~19,000 mi) and still look fine, but then they've kind of toughened with age...
You seem to have a double-posting issue.Yes, the Pirelli's (and rotations every other oil change) have solved the problem. The OEM tires just plain suck.
My '03 GT also has badly cupped 17" Dunlops, with a similar rotation schedule, proper air pressures. For what it is worth, I noticed a Mitsu Eclipse with the same Dunlops - they were cupping too.
My '03 GT with the 17" Dunlops was also badly cupping. I noticed it at around 20,000 miles, it was making a loud vibration when coming from high speeds to low speeds and they howled. I took it in and they thought it was a front wheel bearing first, but that didn't fix it. That was when my service tech said they were "cupping on the outside and feathering on the inside."
2003 Pontiac Vibe GTNeptune with Navigation and 17"s
I have a new AWD vibeless than 6000 miles Had only one oil change so far and noticed my fronts are cupping on the outside. I run between 30-35 pressure all the way around. I know the sticker says 35 front and 32 rear. I should be fine there.I do have the INfamous Conti's
