Transmission Click
Pix Doc
Transmission Click
Post by Pix Doc »
My vibe has an Auto Trans. After it sits overnight, or all day, it makes a faint metallic click when I put it in reverse. It only happens once. If I put it in drive and then in reverse after that is does NOT click. Anyone experience this?
Base 2-Tone Salsa -- Photos of my Vibe and Mods HERE-----> http://www.pbase.com/pixdoc/vibe_picsCustom ExhaustEnkei MM2 (Anthracite) WheelsViper Alarm W/ remote startSilverstarsJVC KD-SX780 Head Unit - Kenwood KFC-1689ie speakers - Apple iPodS2000 Honda Antenna - Bumper ProtectorN0 Badges or Luggage CrossbarsMMMMMMM......SAAALSA
NSimkins
Global Moderator
Re: Transmission Click (Pix Doc)
Post by NSimkins »
How new is your Vibe??I had this same noise for a day or two then it went away when I first picked up my Vibe. A few other members had the same experience.As far as what I have read, most dealers are saying this is a normal occurrence and will go away after some time.Here are a few threads that discuss the problem, but note that not everyone has the same issues. I would recommend you waiting it off a little bit if it isn't a huge annoyance to you. Don't get the dealers changing/swapping/replacing things unless necessary. That may only cause problems.http://forums.genvibe.com/zerothread?id ... ead?id=445
Pix Doc
Re: Transmission Click (NSimkins)
Post by Pix Doc »
Hey, thanx for the info. My vibe is 4 days fresh! I will check the links.
