Yeah so as I was pulling the pins out of the stock stereo adapter a couple of them accidently touched and shorted out all the internal lights (I think) so I'm assuming it blew one of the fuses, problem is which one? I didn't have time to look under the dash to see if one was obviously fried, but does anyone know which fuse controls the indoor lights (dome light fuse?) and what size and type of fuse it is?
Same thing happened to me when I removed my subs but I blew out the fuse for the stereo. All you have to do is open the fuse box under the steering wheel and look at the cover it tells you wich fuse controls what and the type of fuse.
Not to preach, but this is why we get the wiring harness so we don't have to mess with the factory wiring harnesses..
