Motor mounts and shifter bushings?
savedbyzero
Post by savedbyzero »
I know there's a couple of you out there. I was just wandering how much of a difference these mods made.The bushings in the shifter, I feel, could only help! The darn 6 speed gets SO notchy after awhile. Will this help remove some the sloppiness?As for the mounts, did it cause noticeable vibrations in the cabin?Thanks for the input guys!
THIS IS WHAT I DO...http://www.studiothisis.com
Faultline
Re: Motor mounts and shifter bushings? (savedbyzero)
Post by Faultline »
Quote, originally posted by savedbyzero »I know there's a couple of you out there. I was just wandering how much of a difference these mods made.The bushings in the shifter, I feel, could only help! The darn 6 speed gets SO notchy after awhile. Will this help remove some the sloppiness?As for the mounts, did it cause noticeable vibrations in the cabin?Thanks for the input guys!I am putting the mount inserts on friday, so I will find out. I have the 5 spd though.
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
savedbyzero
Re: Motor mounts and shifter bushings? (Faultline)
how much did you get them for?
CaCathy13
Post by CaCathy13 »
I have both in my GT. Big difference. Huge. Massive.There is more vibration, nothing excessive though...the mounts are amazing though. I went from having the torque brace to the mounts, so I can only imagine stock to mounts. Get them. Now.
CathyWhen this baby hits 6.000rpm's, you're gonna see some serious sh*t-Got Lift?'03 Neptune Vibe GT: SLP Hood, AEM CAI, Thermal R&D exhaust, Unorthodox underdrive pullies, K&N filter, G-Racing 17' Mito's, TEIN Springs, yellow calipers, GrafxWerks, Silverstar's, XM, Infinity basslink-more mods to come!http://www.mitro.net/vibe
Devlop
Re: Motor mounts and shifter bushings? (CaCathy13)
Post by Devlop »
I have the mounts. I love them. There is a little more vibration, but nothing I don't mind. Plus, it helps a ton with wheel hop. I barely get any, its great for hole shots.
Faultline
Post by Faultline »
Quote, originally posted by savedbyzero »how much did you get them for?$30.00 at http://www.ptuning.com you have to order them as "Matrix" because it is not listed for Vibe
sharky_9901
Post by sharky_9901 »
How long did the install take?What kind of tools did you need?Does anyone have pics, or an electronic copy of directions
'03 Neptune GTTop speed 130mphStrut BarFlowmaster 40 SeriesAEM CAIWindow Tint
Devlop
Re: (sharky_9901)
Post by Devlop »
I installed them when I installed the turbo. For the rear, I had the exhaust mamifold out, so it was easy to get to. On the front, I removed the fan shroud to get to it. They weren't too hard, but like I said, I was shnging the exhaust manifold, so that made the rear easy.
blk182@n7
Post by blk182@n7 »
I got the brass bushings and can i tell you the trany shifts 100% better clean and percise...http://www.speed-source.net/pr...e.htm
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
polaris1000
Re: (blk182@n7)
Post by polaris1000 »
I have the E.S. Motor Mounts and Brass Bushing and have to say it is a must for any GT owner. The mounts took about an hour and a half and the bushings took 15 minutes. The best $60.00 I have spent so far!!!!!! The bushing take alot of the notchiness away and the motor mount really make it easy to drive. It is not like trying to learn stick all over again.It is much easier with 2 people to do the mounts. There is some vibration, but I have heard that it dies down after a couple of weeks. If you are unhappy with the Vibes notchy feel and strange way to launch, GET THESE MODS!!!!!!!!!
http://members.cardomain.com/pontiacvibegt MagnaFlow Cat-back Exhaust Injen CAI TRD Lowering Springs TRD Ground Wires TRD Strut Tower Brace Progress Rear Sway Bar E.S. Motor Mounts
AKLGT
Re: (polaris1000)
Post by AKLGT »
ya i want some too. but i'll have to wait til i get my pfd. and probably just the shifter bushings since those look like something i can handle myself.
AKLGT1998 Subaru 2.5RS
Psychobroker
Re: (trdvibe)
Post by Psychobroker »
I concur with everyone else to comment....HUGE difference!Aside from cabin vibrations, which I don't even notice anymore, both mods have helped with the overall response of the car. Both mods give me a better "feel" of the engine, shifts, etc.
St. Martin
Re: (Psychobroker)
Post by St. Martin »
...Just bought a set of both. I'll give you my two cents when i get them in in about a month or so.
Sold the vibe.Sorry, GM. I bought an Acura.
St. Martin
Re: (St. Martin)
Finally got the bushings in (my car has been out of my posession). HUGE improvement and very quick and easy install. If you hate the way this car shifts, buy these. Seriously...right now. Go buy them.
