I like how they don't tell you the brand.... I dunno just cause of that I might not buy them but you might not care if they are non-branded tiresTread wear rating is decent and pretty good traction and temp wear (A is right below the best rating which is AA). Cool that they are 40's altho the means you will probably need a speedometer recalibration since the diameter will be different than stock.They aren't true performance tires if thats what you were going for (you can tell because of the HR rating) which means its only been tested "safe" up for some speed which I can't think off off the top of my head but I think its below 90, which most people don't plan on going unless you like racin gon the freeway or like testing the topspeed.
