rattling driver window
viBert
Post by viBert »
I have noticed that my driver side window rattles when its partly open. I have the vent visors (aka side window weather deflectors) installed to allow me to crack open the windows, so this is a pain.Has anyone got had this problem?
Base 2 tone Salsa, auto, power pack Mississauga, Ontario, Canada I'd rather be sailing but the Vibe makes me a happy landlubber.
mkl116
Re: rattling driver window (viBert)
Post by mkl116 »
mine rattles also....looks like lots of clearance for window to rattle
fire_502
Re: rattling driver window (mkl116)
Post by fire_502 »
Ok, since I'm pretty new here, I did a search to see if anyone has ever brought up the issue with the front windows shaking and I only found these two posts, so I'm bringing it up again. Has anyone else had any problems with their windows? Mine seem to shake a lot when I'm on the expressway and they are open a couple inches. First I thought maybe just the driver side was doing it, but it's the passenger side too. I'm willing to let it go as a little quirk, but I'm just afraid it's going to damage the rollers in there or something. Maybe it's normal, but the windows on my Breeze never shook like this. Any ideas?
Re: rattling driver window (fire_502)
quote:Has anyone else had any problems with their windows?Sure have.quote:Mine seem to shake a lot when I'm on the expressway and they are open a couple inches. First I thought maybe just the driver side was doing it, but it's the passenger side too.I noticed the same exact thing with mine. If they're barely down, they rock back and forth at higher speeds. They can be wiggled back and forth with very little effort. Even the rear windows are doing this on my car. Also, they tend to make a bit of noise when closing any of the doors if the window is cracked slightly. Since all four are loose, either they're supposed to be this way, or my car has issues. I figured the ventshades would cut down on turbulence for the front windows, but no such luck.No leaks, and haven't noticed any wind noise so I'm just gonna guess this is just how they are... Perhaps there is a valid reason they have so much play.
