Weapon-R Throttle Rotor
Psychobroker
Post by Psychobroker »
What are the cons of installing an a/m throttle rotor, such as the one in this eBay auction:http://cgi.ebay.com/ebaymotors...=WDVWThanks everyone.
ladydog
Re: Weapon-R Throttle Rotor (Psychobroker)
Post by ladydog »
The biggesr con for me would be that guys feedback on e-bayLadydog
Psychobroker
Re: Weapon-R Throttle Rotor (ladydog)
True, but I'm just curious about the A/M rotor and it's effects.
Raven
Post by Raven »
I know it's kind of off topic but this guy has the WORST feedback I have ever seen and I am an Ebay junky!
Jahntassa
Post by Jahntassa »
I think the con would be the possibility of ripping up the throttle, or the throttle cable when you try to floor it. This basically just provides less travel on the gas pedal before you hit wide-open.I guess it could be useful on racing, but I'm not sure if my fears would be justified or not.
vibemoon
Re: (Jahntassa)
Post by vibemoon »
If you are going for looks, it might look good. But if you are looking to have a more respnsive throttle simply adjust the throttle cable where it mounts just above the rotor.
'05 AWD Mono Moonstone VibeCosmo CAIPBR Ground WiresEibach Pro Kit SpringsQuote: Of all the things I've lost, I miss my mind the most!
Psychobroker
Re: (vibemoon)
*BUMP*I've got the rotor at home now, and I'm just waiting to hear from some of the more knowledgeable folks around here regarding the pro's and con's of this simple - and tempting - mod.
satur9
Re: (Psychobroker)
Post by satur9 »
just put it on!!!what is it like 5 mins,you dont like it take it off.you not going to harm anything by putting it on.
Psychobroker
Re: (satur9)
Quote, originally posted by satur9 »just put it on!!!what is it like 5 mins,you dont like it take it off.you not going to harm anything by putting it on.I'm not too sure about that. Logic tells me that overextending the stock throttle cable is a bad thing. Is the likely to happen? Could this mod affect the valve springs as well?
Jahntassa
Post by Jahntassa »
Well...try watching the throttle when you open it all the way, then mount the new piece..it might not overextend, just change the curve of how much power is given in the push of the gas...
MadBill
Re: (Jahntassa)
Post by MadBill »
Per my note on a related thread, to speed up the overall throttle opening the 'rotor' must shorten the pedal travel*. Therefore either the pedal must be closer to the floor on idle, or the throttle will reach full open with the pedal not yet on the floor, thus risking a broken cable or bent throttle shaft. *(unless it is actually much slower once the throttle is partly open)
satur9
Re: (MadBill)
Post by satur9 »
i think it has enough slack not to break .when i put in my nitrous system.pedal to the floor still wasnt wide open throttle. the throttle blade had a bit more travel before it was truly wot.
Psychobroker
Re: (satur9)
thanks guys, I think I'll give it a shot this weekend.
