injen cai dirty?
mrgrn
injen cai dirty?
Post by mrgrn »
I have the cai from injen and i seem to have lost some performance from it? it take off slower from first, and i have to use more clutch. I have maybe 12-14k miles on the original filter, can it just be dirty? i picked up some K&N air filter cleaning stuff at the local rip-off shop, they said to use this? They also tried to sell me a new injen fiter for $99, (removed)?
loud pipes save livessmall plates save licenses
Mavrik
Re: injen cai dirty? (mrgrn)
Post by Mavrik »
Yeah I'd clean that filter if I were you, it could be the problem. I know most people seem to clean theres a lot more then you would with the stock air filter. Mainly because its out in the open like that.Give that a try yeah and go from there.
nismo
Post by nismo »
you're actually supposed to clean ur filter every 10-12k miles. At least, that's what I'm gonna do.Inder Singh
2008 Chevy Cobalt SS Turbo - Fun stuff under there somewhere 1998 Nissan Sentra - Sold2004 Pontiac Vibe - 107k and SoldCosmo CAI
redlava
Post by redlava »
Quote, originally posted by mrgrn »They also tried to sell me a new injen fiter for $99, (removed)?I would order a second filter on-line, much cheaper. They tried to sell you the second one probably because it will take a few days for the oil to dry in the recharge and cleaning kit. And it isn't a good idea to drive with no air filter on your car. I plan on buying a second filter when I go to change mine.Go to http://www.ptuning.com and you can get a replacement filter for about $50. If you look you can probably find universal filters for less.
nismo
Re: injen cai dirty? (redlava)
Post by nismo »
Honestly. It takes about a half an hour for the filter to dry off. So, you're good to go. After that. It's not like you're supposed to submerge the filter in a bucket to clean it. There's the kit that tells you how to do it. Very easy by the way.Inder Singh
blk182@n7
Post by blk182@n7 »
I clean mine about every 5000 miles with the K&N cleaner and i have a K&N filter on my AEM..
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
wicked1981
Re: (blk182@n7)
Post by wicked1981 »
This is what Injen says about cleaning..Can my filter be cleaned or does it need replacement?All Injen Air Filters can be cleaned using cotton gauze air filter cleaners and oil that can be purchased from most major auto part stores.We suggest cleaning the filter every 30,000 miles or when it becomes visibly black in color. We recommend examining the filter every 9,000 miles.
2006 Pontiac G6 GTP3.9L V-6 240hp and 241 lb-ft or torque18" Aluminum, five-spoke, flangeless200 Watt, 8 speaker Monsoon sysChrome dual exhaust tipsLiquid Silver MetallicBorla Custom ExhaustDr. Speed Cold Air Intake
nismo
Re: (wicked1981)
Post by nismo »
Yeah. That makes sense. I've had mine. I've put about 3k miles on it already within a month. Before I went on a trip to the east coast, I got an oil change. I was over when I got back. So, yeah. I drove a lot. I had 13k before I left came home with 16k miles. Changed the oil before that at 12k miles.Inder Singh
AKLGT
Post by AKLGT »
i usually clean mine every 15-20K miles. and i use the k&n filter cleaning kit. works just fine. but you may want to clean your MAF too since sometimes the oils will get on it and cause it to get all gunked up too. just be careful if you clean it so you don't blow it out.
AKLGT1998 Subaru 2.5RS
mrgrn
Post by mrgrn »
thanks guys i treid to get the filter off and what a pain in the neck. i have the K&N cleaner stuff and will tackle that this coming weekend.
satur9
Re: (mrgrn)
Post by satur9 »
i just got my k&N the filters come pre oiled out the box right?!? i dont need to oil it first time.
AKLGT
Re: (satur9)
Post by AKLGT »
nope. should come pre oiled. but you should let it stand in the air overnight so it's not too oily or it might gunk up your MAF and throw a CEL.
