hesatation on take off
blk182@n7
Post by blk182@n7 »
has anyone had the hesatation on take off in the GT? I have taken off in a higher rpm range and it still does it but in the 5000 range the tires spin and no hesatation....after changing some parte it would go away but always comes back... could it be the gas?
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
Smokin' Rubber
Re: hesatation on take off (blk182@n7)
Post by Smokin' Rubber »
it takes the engine a little bit to build up a vacuum which is why it hesitates before going, not sure how you can fix that tho
blk182@n7
Post by blk182@n7 »
Hmm thats sucks..I just don't want to have the rpm's to high and just spin the tires...
Smokin' Rubber
Re: (blk182@n7)
I know you need to get racing slicks for high rpm launches and you need to get them really hot and sticky so they with get tractionUsually if you have it at about 3,000 rpms in neutral and the clutch is in a bit the lag isn't as bad and you don't burn out you just chirp a bit
03VibeGT6Spd
Post by 03VibeGT6Spd »
if it's a vacuum issue, add a vacuum booster.
