Water Softener use
GoLowDrew
Water Softener use
Post by GoLowDrew »
We just got a water softener from Sears. They tested the water and said that it need to be set at "9".Question:Someone at work told me that I need to adjust the setting by at least 5 (5 = 1 ppm?) because of Iron in the water.Can anyone comment on that?
2004 Vibe, Auto Trans. Built Sept 2003. Date in service May 2004. Sold May 2006.
ragingfish
Re: Water Softener use (GoLowDrew)
Post by ragingfish »
I couldn't tell you for sure...but I know that we use an additive called "Iron Out" to reduce the iron concetration in the water.Might wanna ask your plumber or installer their professional opinion...
2009 PONTIAC G8
pmh013
Post by pmh013 »
I would get a testing kit. We bought ours from a USF Watergroup (there's a factory here). I think it was about $30?The kit allows you to test your own hardness ... but I think that actually setting the softener is a bit of a guessing game, and it all depends on the model & capacity of the softener. Before we installed the softener, our water was 33 (grains per gallon are the units, I think) and now it's 1 or 2.
2003 Satellite AWD Two Tone, traded off at 180,126 kmNow the (fourth) catalytic converter is someone else's problem Now driving a 2007 Dodge Grand Caravan
Stang2Vibe
Re: Water Softener use (pmh013)
Post by Stang2Vibe »
Quote, originally posted by pmh013 »The kit allows you to test your own hardness ...You need a testing kit for that now? Sorry, I just couldn't resist.But seriously, I would think that it would be difficult to know how to adjust the softner without establishing a benchmark reading and testing periodically to see if adjustments are needed.And be careful not to drop any Viagra into the water!
