Stock 6 CD Radio Wiring Diagram
retiredfields
Post by retiredfields »
Anyone know the wiring diagram colors for the 4 speaker wires at the rear of the stock 6 CD radio? I want to tie in at the rear of the radio for a separate powered bass speaker.Thanks in advance......
russ257
Re: Stock 6 CD Radio Wiring Diagram (retiredfields)
Post by russ257 »
'03 VIBE AWDPioneer AVIC-N1MOMO 6.5" componets in frontMOMO 6.5" speakers in rearJL e6450 six channel ampJL 12" w3 subAlpine 120W amp powering the sub
vibeInCanada
Post by vibeInCanada »
I have the diagram, now which wires would I hook up to my amp for either a sub or a set of 6x9's in the rear? Do I have to split some existing wires?I don't want to lose the existing speakers and amp setup. That is, I want to add another amp.Thanks
Jahntassa
Post by Jahntassa »
You can just use some T-Taps on the rear speaker wires, or front, depending on what you wanna do. You shouldn't have to cut anything.
vibeInCanada
Forgive my ignorance but what are T-Taps???Would I put these before the factory amplifier (ie] the inputs to the factory amplifier) or after the factory amplifier? (ie] the output of the factory amplifier)Thanks for the quick reply....
